Are these 318 motor mounts? #873563
12/07/10 01:44 PM
12/07/10 01:44 PM
Fort Wayne,Indiana 46845
mopar 394 Offline OP
Had problems getting all the stuff lined up in the engine compartment on my 69 Dart 340 so I took off the motor mounts. Aren't these 318 motor mounts?
Re: Are these 318 motor mounts? [Re: mopar 394] #873564
12/07/10 06:20 PM
12/07/10 06:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The passenger side engine bracket is the sam , the drivers side is different. 340/360 requires one that is wider across the ears , what is the problem you are having ?
Re: Are these 318 motor mounts? [Re: JohnRR] #873565
12/07/10 06:50 PM
12/07/10 06:50 PM
With these mounts on the car I had to push the motor and Transmission forward about one inch which caused the drivers side header to hit the steering gear box and the fan/clutch was to close to the radiator.
Re: Are these 318 motor mounts? [Re: mopar 394] #873566
12/07/10 07:27 PM
12/07/10 07:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Where did you get those brackets ?
Did you have them on the right side of the block ears ?
Re: Are these 318 motor mounts? [Re: JohnRR] #873567
12/07/10 09:36 PM
12/07/10 09:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
273/318 bracket is wider than 340/360 one.
Don't be the exception.
Re: Are these 318 motor mounts? [Re: Supercuda] #873568
12/07/10 09:42 PM
12/07/10 09:42 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Answered in the header thread.
They are B and E body brackets. Drivers side is a 340 mount, pass side is a 318/340/360 mount.
You need a bracket with the holes near the other side of the bracket.
Note where the holes are in comparison to the wedge looking bracket you currently have. The ones pictured are A body drivers side, 318 mount converted to 340 style on left and a std 318 mount on right.
Re: Are these 318 motor mounts? [Re: Supercuda] #873569
12/08/10 11:52 AM
12/08/10 11:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks for the correction , it's been 30 years since I swapped a 340 in place of a 318 .
