Re: Help ID this hemi cranks [Re: Quicktree] #871936
12/05/10 07:56 PM
12/05/10 07:56 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
My Crower 4.625" started with an E, and was 5 digits the best I remember.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Help ID this hemi cranks [Re: Quicktree] #871937
12/05/10 08:11 PM
12/05/10 08:11 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
any information is usually on the face of the front counterweight.
yep thats where I found this E23489 anybody have any idea?
E23878
these numbers came from a page on their closeouts.
I would look no further and call them for info
home of the
Sox and Martin Hemi Duster
Re: Help ID this hemi cranks [Re: HEMIFRED] #871938
12/05/10 09:04 PM
12/05/10 09:04 PM
Q
Quicktree Offline OP
Q
E23878
thanks Fred, I am really not concerned. I am pretty confident it's a billet Crower.
Re: Help ID this hemi cranks [Re: Quicktree] #871939
12/05/10 09:07 PM
12/05/10 09:07 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Top of the line build forgot to include flat washers under those top of the line main bolts.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Help ID this hemi cranks [Re: DusterDave] #871940
12/05/10 09:24 PM
12/05/10 09:24 PM
Q
Q
are they really needed? is there any reason to have concern?
Re: Help ID this hemi cranks [Re: Quicktree] #871941
12/05/10 09:46 PM
12/05/10 09:46 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
ARP includes them for a reason. I would think leaving out the hardened and ground washers would throw off your torque value a little. What advantage is there to leaving them out?
Re: Help ID this hemi cranks [Re: DusterDave] #871942
12/05/10 09:49 PM
12/05/10 09:49 PM
Get-X Offline
Get-X  Offline
Not to mention who uses Oliver rods and billet cranks and doesn't use main studs?
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Help ID this hemi cranks [Re: Get-X] #871943
12/05/10 10:02 PM
12/05/10 10:02 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I was gonna go there, but I didn't want to sound too critical.
Re: Help ID this hemi cranks [Re: DusterDave] #871944
12/05/10 10:15 PM
12/05/10 10:15 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
The purpose of the washer on arp's is to give the radius on the bottom of the bolt head room to sit flat. If not the bolt would gouge into a drilled hole that wasn't radiused.
Either way a hardened washer is good insuarance.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Help ID this hemi cranks [Re: bigtimeauto] #871945
12/05/10 10:27 PM
12/05/10 10:27 PM
Q
Q
good to know, this is the way I bought it, and can't complain a bit easy fix it has studs on the top end. guess the builder didn't think it was needed
Re: Help ID this hemi cranks [Re: Quicktree] #871946
12/05/10 10:39 PM
12/05/10 10:39 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
don't put studs in it now, just put washers under the bolts, and use the correct torque for the lube you use. one at a time.
