overfilled transmission what can be damaged?
#87036
07/10/08 11:21 PM
07/10/08 11:21 PM
moparpollack
Lil Herman
Lil Herman
85086
What damage can be done with an over filled transmission? The transmission is a 904 with manual valve body and a smaller than stock convertor.Less than a mile driven I will drain it out tomorrow.
Re: overfilled transmission what can be damaged?
[Re: dOc !]
#87038
07/11/08 12:08 AM
07/11/08 12:08 AM
Posts: 720 Texas
jetdoctor_75402
super gas
super gas
Texas
welllll, lets see now, 1969 Charger RT 440/TF automatic and the previous owner, changed the filter and re-filled the trans. Drove it from Garland TX to Greenville, TX, about 40 plus miles. Made it to Lake Ray Hubbard Bridge, about 8 or 9 miles from his shop and noticed lots of white smoke billowing from under the car and out the tailpipes (I thought). Turns out, they filled the trans with car shut off and it was a tad overfilled. Took 5 quarts of fluid to get home. When we dropped trans, we replaced the front pump seal, rear seal the o-ring on the dipstick tube and that was plenty enough. So yea, you can damage a few "inconsequential" things when you over fill a torqueflight. regards, doc
[Re: jetdoctor_75402]
#87039
07/11/08 12:18 AM
07/11/08 12:18 AM
moparpollack
Lil Herman
Lil Herman
85086
Thanks for the help.
[Re: dOc !]
#87042
07/11/08 09:29 AM
07/11/08 09:29 AM
Posts: 1,061 New Mexico
dmerc
New Mexico
I just reread the post.. Whoops, Never mind!
[Re: RodStRace]
#87045
07/11/08 09:13 PM
07/11/08 09:13 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
just like an engine, there is a level inside that should not be exceeded. If it is, the fluid can get whipped into foam and then you are pumping air and ATF through the trans. It can damage the bearing surfaces, but it would take more than a mile or 2...
An engine has a crankshaft with arms sticking out a few inches, like a kitchen mixer. What sticks out on a tranny shaft to beat fluid into a foam?
[Re: Vert]
#87047
07/11/08 10:21 PM
07/11/08 10:21 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Ever see a shake mixer? It's just a long rod with a disc at the end. It still mixes...
[Re: John_Kunkel]
#87048
07/12/08 02:32 PM
07/12/08 02:32 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Hey Doc ...sounds like you went through alot of work for nothing ! .... other than barfing ATF out the vent how would this over-fill process "hurt" the front and rear seals and dip-stick O ring ?
My question too, barfing out the vent and (possibly) foaming are the only negative consequences to overfilling.
Foaming over a long period can cause internal damage but modern fluids have pretty efficient anti-foaming agents. In a somewhat well publicized stunt on another forum I poured a quart of fluid into a mixing bowl and stirred it with a hand-held electric mixer; no foaming.
I totally agree with what John said. Ron
[Re: John_Kunkel]
#87049
07/12/08 03:39 PM
07/12/08 03:39 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Plus a little-bit o' horsepower loss ! ... but other than that ....? ... nada !!
