CRANKING COMPRESSION #868918
12/01/10 04:33 PM
12/01/10 04:33 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Whats the "GOOD,BAD AND UGLY" of cranking compression??? It was suggested by Rick(aarlucas) that I do it,so I did.
I checked #1,#2,#7 and #8 and all were between 180-200.
Re: CRANKING COMPRESSION [Re: MIKES_DUSTER] #868919
12/01/10 05:02 PM
12/01/10 05:02 PM
organ
maximum entropy Offline
organ
cranking compression is a good measure of the compatibility of a given combination. beyond that, it's not very useful as a diagnostic procedure. in school we had a 327 shivvie mule on a dyno that we conducted all manner of horrific and cruel experimentation. one of the pistons had a hole drilled in it (i think it was about 1/4 inch?). that cylinder had almost the same compression as the rest of them. learned a lot on that engine.
Re: CRANKING COMPRESSION [Re: maximum entropy] #868920
12/01/10 05:11 PM
12/01/10 05:11 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I would be more concerned about consistency between cylinders. Cranking pressure will depend on cam design and compression ratio. You can have 14-1 pistons and a ton of cam duration and the cranking compression will be low. Properly matching the components will result in the best combination. Don't know much about your combo, but 180-200 psi is very good.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: CRANKING COMPRESSION [Re: Dads426] #868921
12/01/10 05:37 PM
12/01/10 05:37 PM
Thanks guys!!!! Hers the run-down on my combo.
360 balanced
.040 (368")
stock crank/rods
ARP bolts
KB-191's
12.3:1 comp.
Ultradyne roller cam
.556/.556 .285/.295 .249/.259@50 (1.5 rockers)
J-heads flowed 284@.525
2.02/1.60
1.6 Crane gold roller rockers
M-1 ported
1" 4-hole spacer
worked 850dp
Re: CRANKING COMPRESSION [Re: MIKES_DUSTER] #868922
12/01/10 10:25 PM
12/01/10 10:25 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Mike..sounds like a NICE combo to me!!!
Re: CRANKING COMPRESSION [Re: Labratt] #868923
12/01/10 10:40 PM
12/01/10 10:40 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
12.3:1 comp.
I do like Ultradyne Cams
Re: CRANKING COMPRESSION [Re: Dads426] #868924
12/01/10 10:48 PM
12/01/10 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep.... I have 14.1:1 and only have 175 cranking compression
mainly due to the 112 lsa... but my engine never
see's lower than 5600 and thats the launch rpm
Re: CRANKING COMPRESSION [Re: MR_P_BODY] #868925
12/02/10 12:36 AM
12/02/10 12:36 AM
I dont have the best gauge so it could be closer than what it read today. Not sure what the LSA is,looked on Bulletcams.com and it dont say.
Bob...Ultradyne cams ARE good cams!!!
Randy....Thanks!!!
Re: CRANKING COMPRESSION [Re: MIKES_DUSTER] #868926
12/02/10 12:44 AM
12/02/10 12:44 AM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Mike,a while back I checked 4 cylinders on the 440,and got readings of 180,182,185,and 182 again! Not too bad!
Re: CRANKING COMPRESSION [Re: Labratt] #868927
12/02/10 12:50 AM
12/02/10 12:50 AM
So,you think I can run pump gas(93-94) or will I have to mix race fuel with it?? If/when I race it,I will run straight race fuel. Was just asking for around town.
5600rpm launch????? LOOK OUT!!!!!
Re: CRANKING COMPRESSION [Re: MIKES_DUSTER] #868928
12/02/10 12:57 AM
12/02/10 12:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Would depend on temp, quench, timing and IF you
truely get that octane... if you truely have 200
that MAY be a bit much... JMO
Re: CRANKING COMPRESSION [Re: MR_P_BODY] #868929
12/02/10 01:13 AM
12/02/10 01:13 AM
Kinda thought that. Gonna recheck tomorrow.
Re: CRANKING COMPRESSION [Re: MIKES_DUSTER] #868930
12/02/10 09:41 AM
12/02/10 09:41 AM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
12.3:1 comp and iron J-heads You will need better gas than 93
Re: CRANKING COMPRESSION [Re: bp27] #868931
12/02/10 11:03 AM
12/02/10 11:03 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
with aluminum heads,.039 quench and 195 cranking pressure i ran 93 no problem. cast iron heads may be a problem on pump gas.
