Page 16 of 81 1 2 14 15 16 17 18 80 81
Re: 5 speed pricing info [Re: astjp2] #868039
02/04/11 02:08 PM
02/04/11 02:08 PM
Sugarloaf, PA. USA
JamiePasson Offline OP
Sugarloaf, PA. USA
We do have a waiting list. Tom is right, it is growing. This is comforting knowing that we have some support for this HUGE chance we are taking here. As for the Inland handle. I will attempt to make a modified tower for the Inland handle. If it works, great, if not, hey we tried. As for an Inland shifter ball with the correct shift pattern, You guys are on your own there!
Jamie
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: 5 speed pricing info [Re: JamiePasson] #868040
02/10/11 04:07 PM
02/10/11 04:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jamie
Jamie there is an adapter already available , it should work if an original handle with fit the new shifter .
Re: 5 speed pricing info [Re: JohnRR] #868041
02/11/11 07:20 PM
02/11/11 07:20 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Good article and pictures in June Mopar Action.
Re: 5 speed pricing info [Re: Ply72rr] #868042
02/12/11 01:30 AM
02/12/11 01:30 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Yes, really enjoyed the article.
It's Swifty! Swifty, you toad sucker!
Re: 5 speed pricing info [Re: zrxkawboy] #868043
02/27/11 09:02 PM
02/27/11 09:02 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Jamie,
Two questions -
1. Are all of the bolt holes helicoiled?
2. Are you sure this will fit in an early A-body? I was underneath my 66 Barracuda yesterday and it looks to me like the area where the midplate bolts on might be too bulky for the early A tunnel.
Thanks!
Re: 5 speed pricing info [Re: lilcuda] #868044
03/07/11 03:57 PM
03/07/11 03:57 PM
Bordeaux, France
RAF383 Offline
RAF383  Offline
Bordeaux, France
Jamie, Thanks for all the infos and to have put me in your waiting list, I don't know if I'll be the first one to have one in France, but, will all the reading I've found on this product, I think the time I'll have to wait will worth it!
A big Thanks from oversea
Re: 5 speed pricing info [Re: lilcuda] #868045
03/08/11 12:35 PM
03/08/11 12:35 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
lilcuda,
The bolts are not helicoiled. There is no need to do this. The aluminum that we are using of good. PLUS, no one should be turning bolts in and out on it. Disassembly mean NO WARRANTY. We will be working on fitment of the '64-66 A body cars next.
Thanks,
Jamie
Re: 5 speed pricing info [Re: JamiePasson] #868046
03/08/11 05:20 PM
03/08/11 05:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
lilcuda,
Jamie
What is the warranty ?
Re: 5 speed pricing info [Re: JamiePasson] #868047
03/10/11 05:23 PM
03/10/11 05:23 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Jamie,
I have no intention of disassembling the trans if I buy one, but if I remember correctly, in order to get the trans into and out of an early a body, you have to take the shifter off. It's been 15 years since I had mine out, so my memory might be foggy. I was just concerned about wear of the bolt holes in the event the shifter does need to come off to R & R the trans.
How do I get on the list to find out when you will have a trans that fits the early a?
Thanks!
Re: 5 speed pricing info [Re: lilcuda] #868048
03/10/11 07:29 PM
03/10/11 07:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jamie,
Thanks!
Do you have to remove the shifter mounting plate to get the trans out of the car ?
Re: 5 speed pricing info [Re: JohnRR] #868049
03/17/11 06:52 AM
03/17/11 06:52 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Question Jamie- I assume the bearings in the transmission are common units available from Timken?
Re: 5 speed pricing info [Re: gdonovan] #868050
03/24/11 07:38 PM
03/24/11 07:38 PM
Texas
mprhound Offline
mprhound  Offline
Texas
Jamie, any update on a time frame for release?
Re: 5 speed pricing info [Re: mprhound] #868051
03/25/11 08:29 PM
03/25/11 08:29 PM
O
OLD318 Offline
OLD318  Offline
O
Sorry, I have'nt read all the posts here...
Are you offering Big block and small block bell housings
in the kits or are those going to be separate costs?
Also I keep hearing A-Body and E-Body...
Are there going to be 68-74 B-Body kits?
For both Big block and Small block available (all years 68-74)?
Re: 5 speed pricing info [Re: JohnRR] #868052
03/26/11 03:05 PM
03/26/11 03:05 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
I don't think so. I forgot about that. Been a while since I had the trans out (15+ years!)
Re: 5 speed pricing info [Re: OLD318] #868053
03/30/11 04:28 PM
03/30/11 04:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It uses the stock bellhousing so if you already have a car set up for manual trans it will bolt right in .
I'm pretty sure he has a 69 Down B body tail , 70 up B body uses the same tails as an E body .
Re: 5 speed pricing info [Re: JohnRR] #868054
03/30/11 05:05 PM
03/30/11 05:05 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Gotta have the hemi 4 speed set up though to bolt right in (18 spline) i believe.
Re: 5 speed pricing info [Re: 68KillerBee] #868055
04/01/11 03:08 PM
04/01/11 03:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's just a clutch disc to change .
Re: 5 speed pricing info [Re: JohnRR] #868056
04/02/11 03:18 PM
04/02/11 03:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
And TO bearing
Gus
64 Plymouth Savoy
Dana 60
Re: 5 speed pricing info [Re: fourgearsavoy] #868057
04/02/11 06:04 PM
04/02/11 06:04 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
and maybe even another belhousing. if the bearing retainer is a different size.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 5 speed pricing info [Re: Old School] #868058
04/03/11 11:24 PM
04/03/11 11:24 PM
Montrose, CO
mprtrpr Offline
mprtrpr  Offline
Montrose, CO
May be expensive, but it's nice to have more (maybe better) choices. I've always wanted a 5-speed Dart.
