1970 440-6 timing
#86766
07/10/08 01:41 PM
07/10/08 01:41 PM
after spinning a rod bearing at 250 miles the engine is redone and back in the Cuda. I have the timing set at 10* BTDC and advance is at 34* yet when I back off the gas I get popping out both pipes and it seems I am getting a slight surge action while highway driving. I was told locally to retard the timing about five degrees, do you agree
Re: 1970 440-6 timing
#86767
07/10/08 01:57 PM
07/10/08 01:57 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
No,don't retard it.Check for a fluxuation in the distributer timing advance/retard,or a lean condition first.
[Re: B G Racing]
#86768
07/10/08 02:00 PM
07/10/08 02:00 PM
I agree, probably lean, Especially check the idle circuits on all three carbs.
[Re: Mr.Yuck]
#86770
07/10/08 03:48 PM
07/10/08 03:48 PM
should I plug the vacuum advance and not use it?
[Re: torkrules]
#86772
07/10/08 04:13 PM
07/10/08 04:13 PM
thanks for the tips guys, will see what works.
