dart front brake lines #867723
12/01/10 03:48 AM
12/01/10 03:48 AM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
ok, so i have a 68 Dart GTS with power disc brakes. i need the front metal brake lines. are the lines the same as a 68 Dart slant 6 with manual brakes? i know the distribution block is. if they are different, what is the difference? thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: dart front brake lines [Re: GTSDart340] #867724
12/01/10 09:12 PM
12/01/10 09:12 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The only lines that will be different are the master cylinder to distribution block if I read your question right.
JB Rhinehart, Realist
A-Body's RULE!
