Re: Stock and Super Stock guys who did your head work!? [Re: Brian Hafliger] #866894
12/01/10 03:38 PM
12/01/10 03:38 PM
Poulsbo, WA
ChrisJohnston669 Offline OP
Poulsbo, WA
Sounds like fun! I would need a copy of all the rules but I can make time for that you bet.
Thanks guys....
Brian
Brian I think you can pretty much do whatever you want. Port as much as you want and put as big as valves that it will fit.
Re: Stock and Super Stock guys who did your head work!? [Re: ChrisJohnston669] #866895
12/04/10 10:07 PM
12/04/10 10:07 PM
Poulsbo, WA
Poulsbo, WA
So I found that my engine I have right now is legal for SS/TA. I just need to get a new intake and switch to a 850 carb from the efi.
Class min wt is like 3165. I am a lil over at 3400 lol. Then the index is 9.90. Truck has gone 10.teens. I know we can make it run mid 9s with some changes so maybe I won't need to build a new bullet. Need to go on a diet. Atkins for my truck!
Re: Stock and Super Stock guys who did your head work!? [Re: ChrisJohnston669] #866896
12/04/10 10:31 PM
12/04/10 10:31 PM
detroit area
moderncylinder Offline
detroit area
in a 2009 rulebook it says 3350 lb minimum 8.5lbs/cu inch if you have an auto trans you can be 5% or 250lbs lighter whichever is less
3165lbs would be a 392 inch motor
