Re: SB 4125 K1 CRANKSHAFT [Re: Quicktree] #866560
11/29/10 11:31 PM
11/29/10 11:31 PM
Delray beach, Florida
P
Performance Only Offline
P
I have one, I think ask Dan he should be setting mine up to fit my block
yes, i have yours and a couple others. we've already had yours in the grinder to check index, stroke, taper and out of round. i don't see how any crank could measure any better than this one did. K-1 is doing an outstanding job on their stuff.
aside from a litle extra time to check it all out, they really make my job a lot easier when it comes to putting all the pieces together.
thats great but im still not messing with your pinion angle
thank goodness for that.
machine shop owner and engine builder
Re: SB 4125 K1 CRANKSHAFT [Re: Performance Only] #866561
11/30/10 12:58 AM
11/30/10 12:58 AM
Queensland Australia
moparmacka Offline OP
Leon, why do you prefer to have the oil rings at the pin height. Will it matter that this engine will see alot of street miles also....I heard that the 4.125 doesn't offer the duarbility of a 4.000??????
Re: SB 4125 K1 CRANKSHAFT [Re: AndyF] #866562
11/30/10 01:01 AM
11/30/10 01:01 AM
Andy can you point me in the direction of that info?
Macka
Re: SB 4125 K1 CRANKSHAFT [Re: moparmacka] #866563
11/30/10 02:32 AM
11/30/10 02:32 AM
AndyF Offline
AndyF  Offline
Macka
http://www.moparts.org/Tech/Archive/smallblock.html
Re: SB 4125 K1 CRANKSHAFT [Re: moparmacka] #866564
11/30/10 02:38 AM
11/30/10 02:38 AM
AndyF Offline
AndyF  Offline
Macka
Search is your friend!
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: SB 4125 K1 CRANKSHAFT [Re: AndyF] #866565
11/30/10 03:18 AM
11/30/10 03:18 AM
K
kielbasa Offline
kielbasa  Offline
K
Yes, I've also been curious as to how durable these strokers will be for street life. 5K, 10K, 50K miles?????? I understand there are a ton of variables to answer that question, but if one is to drive these for 5k street miles a year (along with the occasional blast down the strip), how long before the piston skirts etc. get clapped out and time for a rebuild?
Anybody here with firsthand experience that's run one for a few miles?
Re: SB 4125 K1 CRANKSHAFT [Re: AndyF] #866566
11/30/10 04:02 AM
11/30/10 04:02 AM
Thanks, I will have a read
Re: SB 4125 K1 CRANKSHAFT [Re: AndyF] #866567
11/30/10 04:09 AM
11/30/10 04:09 AM
Do you think durability may be an issue with the long arm??? Again a fair few street miles will in order with this too. I'm starting lean toward the 4.125 stroke and 4.125 OR possibly bigger bore with 6.200 rod. What is the absolute max with these siamese blocks? i like the idea of oil pump and pick up clearing the 4.125 with the chev journal too.
Re: SB 4125 K1 CRANKSHAFT [Re: moparmacka] #866568
11/30/10 01:18 PM
11/30/10 01:18 PM
AndyF Offline
AndyF  Offline
I don't see why durability should be much of a factor. What you're building is similiar in dimensions to a Chevy 454. That Chevy 454 combination was used for millions of vehicles ranging from street cars to pickup trucks.
Re: SB 4125 K1 CRANKSHAFT [Re: AndyF] #866569
11/30/10 03:23 PM
11/30/10 03:23 PM
K
kielbasa Offline
kielbasa  Offline
K
454 has either 9.8 or 10.2" of deck height vs 9.6 for sbm, throw in a 6.2 rod (vs the 454's 6.135) - i would think the 454 will have a taller, more stable piston, yes?
Re: SB 4125 K1 CRANKSHAFT [Re: AndyF] #866570
11/30/10 05:31 PM
11/30/10 05:31 PM
That is exactly what friend said to me yesterday!!! I was thinking along the lines of the smaller piston though.
Macka
