SB 4125 K1 CRANKSHAFT #866540
11/29/10 04:07 PM
11/29/10 04:07 PM
Queensland Australia
moparmacka Offline OP
Has any one fitted one of these 4.125 cranks to an engine. What sort of quality are they? Any reliability issues with this stroke? Also what is the best length rod to use? I was thinking 6.200". Chasing around 440 cubes from a siamese 340 resto block. Comments please.
Macka
Re: SB 4125 K1 CRANKSHAFT [Re: moparmacka] #866541
11/29/10 04:35 PM
11/29/10 04:35 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
6.375" for running Normally aspirated with a W style layout intake valve at 2.10 diameter and 4.125" bore.
6.200-6.250 for running nitrous with a larger than 2.15 valve diameter and bore starting at 4.155".
The deciding factor will be the valve layout on your heads and the bore of the piston you run. You can run .060" Valve pocket to ring groove NA. You need to be around .150" if you are running a power adder. This Valve pocket to ring groove is everything on the small block.
Leon
Re: SB 4125 K1 CRANKSHAFT [Re: Leon441] #866542
11/29/10 04:37 PM
11/29/10 04:37 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have one, I think ask Dan he should be setting mine up to fit my block
Re: SB 4125 K1 CRANKSHAFT [Re: Quicktree] #866543
11/29/10 04:55 PM
11/29/10 04:55 PM
Q
Quicktree Offline
Quicktree  Offline
Q
sorry Dan AT Performance Only thats his screen name.
Re: SB 4125 K1 CRANKSHAFT [Re: moparmacka] #866544
11/29/10 05:51 PM
11/29/10 05:51 PM
AndyF Offline
AndyF  Offline
I started a huge thread on here last year on that subject. I've also written some magazine articles on the same topic. So there is lots of info on here on the topic.
Re: SB 4125 K1 CRANKSHAFT [Re: moparmacka] #866545
11/29/10 06:40 PM
11/29/10 06:40 PM
Delray beach, Florida
P
Performance Only Offline
P
Macka
the quality from K-1 has been exceptional from what we've personally seen. rod length is subjective to the builders thoughts but we do prefer to keep it in the .6.2-6.3 range.
we won't sell a product that we know has QC issues, and believe me, there's plenty of that stuff out there. we've been a distributor for K-1 almost since their beginning and couldn't be more happy with the product or their customer service.
machine shop owner and engine builder
Re: SB 4125 K1 CRANKSHAFT [Re: Performance Only] #866546
11/29/10 06:43 PM
11/29/10 06:43 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Dan is the MAN
Re: SB 4125 K1 CRANKSHAFT [Re: Scamp408] #866547
11/29/10 06:51 PM
11/29/10 06:51 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Cheeres to Dan The MAN!!
Very helpfull guy!!
Re: SB 4125 K1 CRANKSHAFT [Re: moparmacka] #866548
11/29/10 07:09 PM
11/29/10 07:09 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
4" crank w a 4.185 bore is what i have =440 ci sb
Re: SB 4125 K1 CRANKSHAFT [Re: fishy340] #866549
11/29/10 09:14 PM
11/29/10 09:14 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
BPE also offers a crank in that stroke.You may ask Rod about a combo and a price before you buy.It will will be well worth your time to ask.
Re: SB 4125 K1 CRANKSHAFT [Re: moparmacka] #866550
11/29/10 09:20 PM
11/29/10 09:20 PM
BPE Offline
BPE  Offline
We use a 6.200" rod, it still gives you enough room to keep the pin out of the oil ring. It also allows plenty of skirt on the piston to keep it stable in the bore. Keep in mind that K1 is not the only one to offer that stroke combination. I also have those available for less. Check out my add in the new products section.
Rod
Re: SB 4125 K1 CRANKSHAFT [Re: fishy340] #866551
11/29/10 10:00 PM
11/29/10 10:00 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
He is looking at using the K1 4.125" stroke. With a 4.125" bore it is 441 CID. Built one. First stroker for me 15 years ago. Screen name Leon441 had that for 15 years also. 4.100" bore will give you 435 CID. 440 just sounds cooler to some.
Nothing wrong with running the pin in the oil ring. In fact I prefer it. Just don't necessarily like to get above the groove.
Re: SB 4125 K1 CRANKSHAFT [Re: Quicktree] #866552
11/29/10 10:30 PM
11/29/10 10:30 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
A HA!! i knew you were up to something with all the smack talk
Re: SB 4125 K1 CRANKSHAFT [Re: sixpackgut] #866553
11/29/10 10:44 PM
11/29/10 10:44 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Ray did you miss he had a block at Dans? Have you ever seen the size of the steam rollers on his car? Bigger engine was needed to turn them, plus I think Tony is going to set Dans pinion angle in trade and possibly put a 9 inch in.
Re: SB 4125 K1 CRANKSHAFT [Re: poisondart2] #866554
11/29/10 11:05 PM
11/29/10 11:05 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I wouldn't touch Dans pinion angle with a 10 pole
Re: SB 4125 K1 CRANKSHAFT [Re: Quicktree] #866555
11/29/10 11:11 PM
11/29/10 11:11 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
lol..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: SB 4125 K1 CRANKSHAFT [Re: poisondart2] #866556
11/29/10 11:20 PM
11/29/10 11:20 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i made a comment in that post and Quicktree lied like a grudgracer
Re: SB 4125 K1 CRANKSHAFT [Re: sixpackgut] #866557
11/29/10 11:21 PM
11/29/10 11:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
not me
Re: SB 4125 K1 CRANKSHAFT [Re: Quicktree] #866558
11/29/10 11:23 PM
11/29/10 11:23 PM
P
P
yes, i have yours and a couple others. we've already had yours in the grinder to check index, stroke, taper and out of round. i don't see how any crank could measure any better than this one did. K-1 is doing an outstanding job on their stuff.
aside from a litle extra time to check it all out, they really make my job a lot easier when it comes to putting all the pieces together.
Re: SB 4125 K1 CRANKSHAFT [Re: Performance Only] #866559
11/29/10 11:27 PM
11/29/10 11:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats great but im still not messing with your pinion angle
