adjusting the gas tank sender
#86547
07/09/08 10:04 PM
07/09/08 10:04 PM
Posts: 4,179 California
mickm
California
putting a new tank in, already have a new sender that has been in for a while.
the gauge would never register more than about 3/4 full, when i filled the tank. it measured past empty when i had 4-5 gallons in it.
with the sender out, i found that at the lowest point of travel it went beyond empty, and at the highest point, a little beyond full. so the gauge works fine.
so what i did was mark where the sender was at 3/4 on the gauge, and then move it up to full, and bend the float down closer to that point. but at that point, the float hits the filter, and does not go down all the way. i assume this is fine, as it probably didn't go down all the way to the stop to register empty anyway, witness my 4 or so gallons and the gauge being past empty.
does that sound right? or does anyone have any other suggestions about adjusting this correctly?
Re: adjusting the gas tank sender
[Re: mickm]
#86548
07/09/08 11:34 PM
07/09/08 11:34 PM
RapidRobert
not much help but I would want to adjust it so that when the needle hit the mark at the E the tank is ALMOST out of gas.
[Re: Mopar-Al]
#86551
07/10/08 12:33 PM
07/10/08 12:33 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I recalibrated one some years ago via resistors, wired them in series at the fuel tank with the sender wire. Had to keep adding resistors in a parallel bundle until I got the right amount (lots of crawling under the car with resistors and then out to check the gauge!). After hitting the right combination I sealed it all with heat shrink. This was for installing a used OEM sender so it's not the same situation.
As I recall it was off by 1/8 tank at one end of the gauge but was close enough for me. It either read E at a true 1/8 tank or never reached full.
I recently installed a new Spectra Premium sender in another car and it's off by 1/4 tank. I think this one needs the float arm rebent. I'll empty the tank, fill it with 6 gallons (24 gallon tank) and see what adjustment needs made to put the gauge to 1/4 tank. 6 gals should be below the gasket of the sender and permit me to R&R teh sender without spilling fuel. Can then maybe hold the float to the top of the tank somehow and see how the gauge looks for full.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: mickm]
#86552
07/10/08 01:00 PM
07/10/08 01:00 PM
i hate to be the bearer of bad news but some of you guys are probably never going to get your sending units to work.
The reason is because many of the reproduction sending units were not built right. Their resistance range from empty to full was not correct. A proper guage should be 10 ohms at full and 73 ohms at empty. you will most likely find yours to a different range. I cant remember what the bad units had for a range but it was something like 0 to 100. that means at 1/4 empty, you will read empty and at full, you'll read 3/4 full
theres no way to fix this as far as i know other than to change out the resistor element to the correct one.
this is a KNOWN problem with reproductions (at least some of them)
#86553
07/10/08 02:12 PM
07/10/08 02:12 PM
I'm not sure I agree with that. If the repop sender has a LARGER resistance change than the old one, it should be possible to add some resistance in parallel with the sender to ground to set the range. Then, it would be a matter of adjusting the thing so that empty is correct on the one end, and adjusting the resistor for full on the other.
Frankly, I'd be happy to have "empty" fairly accurate, but the one thing you do NOT want, is for the tank to be empty before the gauge is!!
Also, don't discount the possiblility that the gauge has become innacurate over all these years, or that if it's been 'repopped' that it's not correct, either.
#86555
07/10/08 04:27 PM
07/10/08 04:27 PM
like I said, I believe if you check it at empty and full, the range on the junky repops are different than the stock ones.
The fact that it only goes to 3/4 full tells me that at empty, it not 10 ohms OR 0 ohms but something greater. I'll do some math and see if I can work it out.
[Re: Beep Beep]
#86557
07/11/08 04:30 PM
07/11/08 04:30 PM
RapidRobert
If I could get it correct on the E end I would be happy with that.
[Re: mickm]
#86559
07/11/08 06:37 PM
07/11/08 06:37 PM
Posts: 1,359 Buzzard County, FL
IronWolf
Buzzard County, FL
I have had success moving the goofy ground strap that clips from the output line past the rubber line. It is flaky. Clean it well , and move it around. Good luck
#86561
07/11/08 11:47 PM
07/11/08 11:47 PM
Posts: 4,085 Indiana
W5Duster436
Indiana
I just bought a 3/8 unit from Mancini a few weeks ago and am having the same troubles. First I didn't check it for binding before putting it in as my gauge would only go to E. So I took it out and checked it and bent it a slight bit just to keep it from hitting the pickup tube. Put it back in and still after putting 5 gallons in it barely reads above E. I ohm'd it out before putting it in but didn't check it against the original (rusty, rusty) unit. I just wanted to verify the full range worked and it did. Can't remember what the readings were but obviously not right. Even as rusty as my original unit is (sat since 1979) it reads 9 ohms full and 63 ohms empty. So I guess that's what my gauge is calibrated for.
Gonna pull this new one back out once again and check it. If I can't get it to work then it's off to the beadblaster to get the original cleaned up and have a 3/8 line put in place of the 5/16. Probably would be okay with the 5/16 though as I won't be over 500hp.
[Re: mickm]
#86564
07/14/08 07:04 PM
07/14/08 07:04 PM
W5Duster436
Indiana
well, this is a bummer. after bending the float DOWN, which logic tells me should place the sending mechanism higher in position for the same amount in the tank, thereby having the gauge read higher for the same amount of gas, it appears to actually be reading a little lower.
i put 9 gallons in, which should be 1/2 gallon short of half a tank, and it barely reads 1/4.
doesn't make sense to me. i will pull it at some point and try bending it some more. i really don't want to go with a bunch of resistors in the line...
oh well, at least i have a tank that isn't leaking gas at $4.60/gallon!
Sounds like adding resistors is the only choice. I am going to take my original sender and have it bead blasted and replace the 5/16 line with a 3/8 line. Sending this one back.
#86565
07/15/08 08:15 AM
07/15/08 08:15 AM
![](/ubbthreads/images/graemlins/whistling.gif)
