UNSURE What To Do #865554
11/28/10 12:38 PM
11/28/10 12:38 PM
MR_P_BODY Offline OP
I'm in the process of building up the Rampage for
the Hot Rod Drag Week and am currently working on
the chassis and body BUT I'm not real sure which way
I want to go with the engine... I'll be running a 408" SB
with a 518 trans(OD)... now the question... should I go
N/A or go with my 8-71 blower... understand that this
will be a street car after the drag week... I will
need to figure this out so I can order up my pistons
and cam... oh yeah... I'll run my W-5 heads on it
What way do you think I should go.... the quickest
I will go(ever) with this car is 10.0 and will only
run 10.80 during drag week(10.80 is the quickest you
can run in Daily Driver Class).... the other factor
is this will be pump gas 93 octane.... I keep going
back and forth what I want to do... I'm getting
dizzy going back and forth.... thanks guys
Re: UNSURE What To Do [Re: MR_P_BODY] #865555
11/28/10 12:41 PM
11/28/10 12:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I would run the class where I could compete the best.
Re: UNSURE What To Do [Re: MR_P_BODY] #865556
11/28/10 12:46 PM
11/28/10 12:46 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
depending on gas prices where you live.id go with the blower if the price of gas is not an issue.nothing like a blown mopar pro streeter
Re: UNSURE What To Do [Re: 2QUICK4U] #865557
11/28/10 12:53 PM
11/28/10 12:53 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
i feel your pain mr.p
Re: UNSURE What To Do [Re: MR_P_BODY] #865558
11/28/10 12:53 PM
11/28/10 12:53 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Go NA. Rather see a Mopar out there going 10.80's on motor than a blown Mopar ONLY going 10.80's, if you catch my drift. Don't need to give the Chevy fan boys any more ammo.
Re: UNSURE What To Do [Re: 2QUICK4U] #865559
11/28/10 12:55 PM
11/28/10 12:55 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Seems the blower would be over kill for the power your shooting for, The w5s will get ya there with a little tweaking
Re: UNSURE What To Do [Re: emarine01] #865560
11/28/10 01:04 PM
11/28/10 01:04 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Something to think about...are you OK with the exposed 8-71, carbs, and the hole in the hood if you have to drive through a heavy rain storm during Dragweek? I don't know how light your Rampage will be, or how hairy the engine will be, but that 10.80 is certainly attainable w/o the blower.
If it were me building a car for DW, I'd instead go with a flat or cowl hood, build a mild 408, and add a small 150 shot of nitrous. It would be a more road worthy, reliable, all-weather friendly setup. Of course, if money was no object, I'd go the turbo/EFI route.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: UNSURE What To Do [Re: DusterDave] #865561
11/28/10 01:20 PM
11/28/10 01:20 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
I agree with Dave shoot it when you need it.
Re: UNSURE What To Do [Re: DusterDave] #865562
11/28/10 01:22 PM
11/28/10 01:22 PM
If it were me building a car for DW, I'd instead go with a flat or cowl hood, build a mild 408, and add a small 150 shot of nitrous. It would be a more road worthy, reliable, all-weather friendly setup. Of course, if money was no object, I'd go the turbo route.
That was my concern... weather with a blower... but
I really think the blower would look cool.... I
expect the car to be 2800 with driver.... these are
the rules for DD class which is really the only class
I can fit in due to my health/license issue(cant
go sub 10.0 for NHRA) but 10.80 is the break for DD
* Daily Driver has no limitations on drivetrain or body modifications. Cars quicker than 10.80 are not allowed in Daily Driver, and e.t. slips quicker than 10.80 will not be accepted.
* Daily Driver entries are not eligible to win Drag Week(tm) overall.
* Throttle stops and bracket-racing electronics of any kind are not allowed.
* Daily Driver is based on an Open Comp format. Each car's five-day average e.t. will be used to determine qualifying position on a 32-car ladder for a bracket race on the final day of Drag Week(tm). At tracks with e.t. slips to four decimals, all four will be included; if only three decimals are on the e.t. slip, then the fourth decimal will be zero. The e.t. averages will be taken out as many decimal places as required to determine qualifying. Ties will be broken by average mph. The race on the final day will be a 32-car field on a Sportsman ladder (1 races 17, 2 races 18, and so on) and a 0.500-second full tree. Normal breakout and first-or-worst rules apply. Each car's dial-in for every round (the dial-in cannot be changed between rounds) will be the five-day average minus a tenth, so a weekly average of 12.20 gets a dial-in of 12.10; in the event that a car averages 10.89 or quicker, the dial-in will be 10.80. Any run quicker than 10.80 will be considered a "worst" and will lose the round. The bracket-race winner will be the overall Daily Driver Champ. In the event of a rainout on the last day, the winner will be the quickest car with the best consistency throughout the week. But there are also a lot of other potential prizes for Daily Driver racers, so read on.
Re: UNSURE What To Do [Re: DusterDave] #865563
11/28/10 01:33 PM
11/28/10 01:33 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
Light car,w-5 headed n/a small block should be fine.Since it will be a street car,I would not like the extra weight up front.All said and done,won't that be about 250 lbs extra with the blower set up?.I agree a blower belongs on a 9 sec car or faster.Even though they look cool as hell.Here's a thought.How about one of those turbo's that mount near the end the exhaust sytem.(depends on how you're running the exhaust)I know there not as efficent/or cool as the intercooled, under the hood unit's,but a little more simple,Might just give you that little extra ooompfh needed.My other concern would be the cost of parts for the trans to stay together with The blower set-up.Save the blower for a street rod.
Re: UNSURE What To Do [Re: emarine01] #865564
11/28/10 01:35 PM
11/28/10 01:35 PM
Az
Crizila Offline
Crizila  Offline
Az
In the long run a NA car will be a better daily = "rain, snow, sleet, and dark of night" = driver.
Fastest 300
Re: UNSURE What To Do [Re: MR_P_BODY] #865565
11/28/10 01:40 PM
11/28/10 01:40 PM
NC
440Jim Offline
440Jim  Offline
NC
Depending on weight, the 408 CID and the W5 heads are plenty to run the 10.80 ET target without the blower. However, if you want the blower just for the novelty on the street and WOW factor, go for it.
Re: UNSURE What To Do [Re: 440Jim] #865566
11/28/10 01:47 PM
11/28/10 01:47 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Mr P, Which combo. would you get the most enjoyment out of? Go with what ever would be the most fun for you to drive.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: UNSURE What To Do [Re: MRMOPAR622] #865567
11/28/10 02:19 PM
11/28/10 02:19 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Both engine combos should easily get you to the 10.80 target, but I think the N/A motor would have to be pretty stout to pull off a 10.00.. unless the Rampage is going to be extremely light..
So forgetting the 10.00 target for a second.. I would ask myself.. Which combo would have better mpg and which combo would be most reliable...
Re: UNSURE What To Do [Re: MRMOPAR622] #865568
11/28/10 02:20 PM
11/28/10 02:20 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
hey Mike... Ive got some spare front drive axles & transfer cases.... if ya want to try something a little different
Re: UNSURE What To Do [Re: emarine01] #865569
11/28/10 02:33 PM
11/28/10 02:33 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I'd rather have a stick shift than a blower for that can when it comes to fun factor. That said, if I (poser) was going to take a car on drag week I'd prefer that it did not have a hole in the hood that could not be easily sealed up during wet weather. I can't wait to see the finished product!
Re: UNSURE What To Do [Re: 440Jim] #865570
11/28/10 02:50 PM
11/28/10 02:50 PM
Jim the car w/driver should be 2800# or less... thats
the problem I'm having... the WOW factor would be
real cool... either way I'm sure I can go 10.0 BUT
the weather factor with a blower has me a little
concerned... the last drag week we went thru the
rain storm from hell... we should have pulled over
but didnt, we were down to 15 mph on the E-way but
so was everyone
The other thing with the blower is height... I dont
want the hat above the roof so I would need to do
some measuring... I'll try to keep the engine low
in the chassis but I can only get so low(I'll make
a custom oil pan) but I still need to worry about
road conditions... decisions... decisions
Re: UNSURE What To Do [Re: MR_P_BODY] #865571
11/28/10 03:44 PM
11/28/10 03:44 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Dumb question, but would turning the hat on the blower towards the windshield help in a ran storm?
In terms of reliability, adding the blower also gives you several more points of failure. Would you run any electronics to reference the timing curve to the boost or keep it simple and set the timing like normal? Also, I am going to assume the huffer would require two carbs and the N/A setup would be a Dominator?
Re: UNSURE What To Do [Re: MR_P_BODY] #865572
11/28/10 03:50 PM
11/28/10 03:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I agree that 10.80 should be a breeze with that car and your W5 heads and a single carb, no need for any power adders. Another thing about the blower is that they are usually NOT consistant and you mentioned needing to run 10.80 like a bracket car.
You can tell by my PM's lately that I'm in the same boat with you on combo decisions, I've had ALOT of very nice trade offers for my Dart lately but I literally can't sleep at night thinking of which way to go. Big block or small block drag car, maybe a street car with no cage, maybe a tube chassis car, stick shift or overdrive auto, power adder or N/A, just go buy new Chally or Mustang,
Good luck with your decisions I'm sure you'll pick a great combo.
Re: UNSURE What To Do [Re: ProSport] #865573
11/28/10 04:06 PM
11/28/10 04:06 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Mike.... just a thought ... maybe a home for the w5 tunnel ram
