Engine test stand ? #865016
11/27/10 08:38 PM
11/27/10 08:38 PM
templeton,ma
coro500net Offline OP
templeton,ma
Can a auto trans be used? should the trans lines be looped? Dont want to spend $200 on a well used bell housing and $100 on a very used flywheeel.
If so should the trans be filled to capacity?
Re: Engine test stand ? [Re: coro500net] #865017
11/27/10 09:21 PM
11/27/10 09:21 PM
Champion City
The Sphinx Offline
The Sphinx  Offline
Champion City
I don't see why not, just loop cooler inlet to the outlet. Make sure you keep it in park and stuff a slip yolk in the tail shaft.
It would be a lot less headache just picking up the bell housing and flywheel off e-bay or in the for sale section here. Maybe someone local could just loan them to you.
Re: Engine test stand ? [Re: The Sphinx] #865018
11/28/10 02:28 AM
11/28/10 02:28 AM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
I use a gutted trans and a TQ cut down, nothing moving inside.
No load on the engine but great for checking leaks before installing in the engine bay
Re: Engine test stand ? [Re: six-barrel] #865019
11/28/10 03:08 AM
11/28/10 03:08 AM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Just considering all options here, could you use manual flywheel with a gutted auto trans case?
Re: Engine test stand ? [Re: coro500net] #865020
11/28/10 04:53 AM
11/28/10 04:53 AM
Yes the cooler lines needs to be looped & I'd fill the trans up. If this is a trans you care about I would consider using a cooler
