Valve length in B1's #863600
11/25/10 07:26 PM
11/25/10 07:26 PM
IL
E
EchoSixMike Offline OP
E
IL
There's a set of 2.300 ti valves on RJ, length is 5.500, stock length for B1 originals is 5.380 per brodix. For MC's it's 5.500. Can 5.500 length valves work in B1 Originals or do things get FUBAR? S/F....Ken M
Re: Valve length in B1's [Re: EchoSixMike] #863601
11/25/10 07:57 PM
11/25/10 07:57 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
Its been awhile since I set up the B1 heads but I remember that the valve length that was recommended was a little on the short side for the T&D rockers that I used.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Valve length in B1's [Re: EchoSixMike] #863602
11/26/10 05:39 AM
11/26/10 05:39 AM
IL
E
E
IL
I know there's some tolerance in rocker setup, I need to know if .12 is going to be too much to deal with. TD 1.6 rockers if it matters. S/F....Ken M
