Trans brake #863345
11/25/10 08:45 AM
11/25/10 08:45 AM
peachland nc
72 cuda Offline OP
72 cuda  Offline OP
peachland nc
I have a racer acquaintance that tells me that Before I put nitrous on my car.
That I should install a trans brake.
It sounded complicated.
I want to do all the work myself, can I do this with a little tutelage from an transmission man?
Also a 2 stage plug that goes in the bottom of the MSD box.
I presently have points?
Should I put an electric distributor first.
This is going to be a pro street strip 72 Cuda.
Slightly confused
72 Cuda
Re: Trans brake [Re: 72 cuda] #863346
11/25/10 09:43 AM
11/25/10 09:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You would need to move the vent for the brake then
install the valve body per the manufactures instructions
BUT you really dont have to have it.... I would get
rid of the points... there are kits to change it over
