Front end alignment question/riddle? #863096
11/25/10 12:41 AM
11/25/10 12:41 AM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
I loaded my car into a moving truck on Friday, drove it roght in the back of a 53' semi trailer. It shows up at my house yesterday, 1500 mile trip. seems fine and everything looks good. I pull it into the driveway after we unload the truck and notice the steering feels odd. I get out and look and this thing has a ton of positive camber on both wheels and the toe in seems to be too much. this is a car I drove regularly over the last three summers. What would cause a car to suddenly have A LOT of positive camber and a bit too much toe in? The tops of both tires are leaned out, that's positive right? Anyway I did call the shipper and they will be out on friday. I am wondering if the driver had the car out for a joy ride and jumped it or something, I do not know and otherwise the car looks fine. Any front end experts?
Re: Front end alignment question/riddle? [Re: Joshs68] #863097
11/25/10 12:43 AM
11/25/10 12:43 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
How did they secure the front?
Maybe something got bent
Re: Front end alignment question/riddle? [Re: WILD BILL] #863098
11/25/10 01:05 AM
11/25/10 01:05 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
for positive camber,the lower control arms would have to be bent.Bent uppers usualy cause neg camber.Is the ride height the same?If the front is higher for some reason, that will camber top out.I have seen saged K-frames,but that usually ends up with neg camber also.If it looks and feels that bad,check for tire wear.If it was driven for a while,there should be evidence of outside tire wear,from the truck up the driveway should not show anything,but if joy-riding,tire wear will be there.Hope there is a simple explanation.
Re: Front end alignment question/riddle? [Re: moretoys] #863099
11/25/10 02:29 AM
11/25/10 02:29 AM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
Bill, That's the strange part. The front was not tied down at all. There were two straps on the rear. Tons of space in the truck and just the rear was tied down. I can not see any evidence of damage. I will take it in next week and see what the shop can find.
Re: Front end alignment question/riddle? [Re: Joshs68] #863100
11/25/10 02:38 AM
11/25/10 02:38 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Does this condition stay after a drive?
I have had situations similar to this. In my case, the K frame was to blame. The hole that the lower controal arm stud passes through was elongated. What happens is that the welds weaken with age, then get wobbled out. This, along with worn LCA bushings caused both Camber and toe changes.
Re: Front end alignment question/riddle? [Re: Joshs68] #863101
11/25/10 02:55 AM
11/25/10 02:55 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Drive it more than "into the driveway" (like around the block) to settle the ride height and see if the problem persists.
If it does, you will need an physical inspection, and not a bunch of guesses from afar, to get to the bottom of this.
There really isn't any part of a proper 1500 mile transport that should have caused this.
PERSONALLY, I don't quite follow the drove it into a semi description, nor the "secured at the rear only" deal. It sounds rather atypical.
Re: Front end alignment question/riddle? [Re: 68HemiB] #863102
11/25/10 09:41 AM
11/25/10 09:41 AM
Raleigh, NC
John426 Offline
super gas
John426  Offline
super gas
Raleigh, NC
I'll guess you backed it out of the trailer and into the driveway and noticed the problem, yes?
I've seen this happen a few times, its usually worn out (like wasted!) brake strut rod bushings. The brake strut rods keep the lower control arm triangulated and when the bushings get pounded out the lower control arm can move forward and rearward with an associated wicked change in camber and toe!
Classic bad bushing symptom. Push the car forward a couple of feet and tell us how it looks then.
Cheers!!
John P.
Re: Front end alignment question/riddle? [Re: John426] #863103
11/25/10 10:20 PM
11/25/10 10:20 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
I did back it out of the trailer, and I did take it around the block. No change. I will figure out whats up and let you know. All the bushing are new as of 3 years ago and have about 2500 miles on them.
68HemiB not sure how I can explain it for you any better. I drove the car into a semi trailer, I drove it out 3 days later, 1500 miles away and the camber was way off. I have pics of me driving the car into and out of the trailer if you want for verification. the movers strapped it down crossing the straps diagonally on the rear. This was a company paid for move, so they load it (although they let me drive it on), they break it and they pay for it.
Re: Front end alignment question/riddle? [Re: Joshs68] #863104
11/26/10 12:17 AM
11/26/10 12:17 AM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
I'd like to see those before and after pics. I really just would like to see more of your car. Nice Ride. The camber issue just don't make sense unless you find evidence of joy riding. Bent rim or grass hanging underneath, or some other factor.
DRIVE EM, DONT HIDE EM.
Re: Front end alignment question/riddle? [Re: Joshs68] #863105
11/26/10 10:16 AM
11/26/10 10:16 AM
Orange Park, FL
MRHWS Offline
MRHWS  Offline
Orange Park, FL
Did you follow the haul from beginning to end or keep the keys in your pocket? Possible the car was taken for a joy ride since it doesn't sound like it would take too much to off load and reload?
1973 Charger SE 1974 Charger Rallye 440 Aztec 2008 Charger SRT8
Re: Front end alignment question/riddle? [Re: MRHWS] #863106
11/26/10 11:01 PM
11/26/10 11:01 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
are you sure your upper control arms didn't loosen up?
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Front end alignment question/riddle? [Re: deansrr] #863107
11/27/10 12:41 AM
11/27/10 12:41 AM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
If the controll arms loosened up, they would fall in. You didn't happen to lower your torsion bars lately did ya?
Re: Front end alignment question/riddle? [Re: ledft79] #863108
11/27/10 12:36 PM
11/27/10 12:36 PM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
I would look at the strut rods or the LCA's. I bet the car had "J" looking hooks that the driver put through the strut rods or around the LCA's in the front that you didn't see.Something got bent up there. I doubt they transported the car 1500 miles with just the back tied down. The car would be into the side of the trailer if they did.
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: Front end alignment question/riddle? [Re: A70Runner] #863109
11/28/10 08:22 PM
11/28/10 08:22 PM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
To find out what happened
