Re: PTC vs COAN results
[Re: KOS]
#862733
11/24/10 09:09 PM
11/24/10 09:09 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
ok first ill give some info on both verts....both are 8"the coan was built for a W2 340 it has a negative fin angle(around 100-150 degree)5500stall behind my new combo stroker indy SB. the ptc was built for a stroker BB +250 fin angle unported stator 5400stall behind the same combo as above. the coan is 10yrs old been behind several combos the ptc is bacially new.i lost almost a full 10th in 60ft with the ptc bacially 1.5ths on the top with same mph and rpm trap(same slippage).i bought the ptc because i wanted to use NOS figured it should be tighter but dissapointed.
Was the PTC built by them for your new combo? Or was "the ptc was built for a stroker BB +250 fin angle" that someone elses combo?
[Re: Troublemaker427]
#862736
11/24/10 09:18 PM
11/24/10 09:18 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Your PTC may very well be a peice of crap.
BUT, these converters are not anyway shape or form the same converter. By your own admission you ordered the converters for different combo's.
[Re: Quicksilver440]
#862738
11/24/10 09:27 PM
11/24/10 09:27 PM
KOS
they where both built for different combos.....my complaint is the slippage of the ptc.it is equal to the coan which is 11%last time i did the math.
[Re: MOPARCHAS]
#862749
11/25/10 11:18 AM
11/25/10 11:18 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
back when i had some money, i bought a PTC and a spragless from TCT at the same time. they ran exactally the same.
TC are one of those things where i wish i could buy 5 different converters and try them all. I now have one from Ultimate
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#862750
11/25/10 12:13 PM
11/25/10 12:13 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
I bought my first and only Coan back in the early 90's for a 13 second 383 Roadrunner........Paid over $500, put it in, drove it around the block, hammered on it a few times, and broke it......When I first stall tested it, it would go to 4,200........After hammering on it for about 10 minutes, it made a huge "thunk" sound.......I thought the driveshaft came out.......after that it would only stall to about 2,200........I pulled it out and the stator splines were split and shattered..........I called them to explain what happened and their very sarcastic response was; "That converter isn't for a B1 motor".........
If you can't handle the truth, you're living a lie.......
[Re: MoparPitBull]
#862752
11/25/10 01:31 PM
11/25/10 01:31 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
One thing, that most people tend to overlook, is that a converter is not an exact science. You may get two supposedly identical converters from two different companies and they act totally different. You may even get two from the SAME company that act different. Like I said, they are not an exact science and two different people, read the same build sheet, there could be some differences, as a lot of the fin work, is done by hand.
The chances of getting the "PERFECT" converter, the first time, from ANY company, are slim, but most don't have a lot lying around to try, to determine this.
Does PTC make a quality converter...yes they do.....does Coan make a quality converter....yes they do. Just because one is faster than the other, does not mean it is a better converter, it just means it suits your combo better than the other.
I can't speak for Coan, because I don't know their policy, but I believe that PTC offers one, free stall change, within a reasonable amount of time, with every new converter they sell, because even they know, you don't get it perfect every time.
I use PTC converters in our drag radial car. We have (3) bolt together converters and (6) stators and every combination of them has been in the car at one time or another. Thats how often we swap converters, looking for the proper one, for given weather and track conditions.
Monte
[Re: Monte_Smith]
#862753
11/25/10 02:49 PM
11/25/10 02:49 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
as usual...so well said Monte... PTC converter here had a HUghes and didnt like it at all these were not off the shelf converters but designed for the application...as Monte stated it isnt exact science but at least when you tell em what your combinations are or what you have...theres no telling how close the converters will be..
[Re: Monte_Smith]
#862754
11/25/10 03:16 PM
11/25/10 03:16 PM
Quicktree
Monte
lets say the track is cold and not so good what changes would you make to the converter to make it better? can you share that?
[Re: Quicktree]
#862755
11/25/10 03:25 PM
11/25/10 03:25 PM
Monte_Smith
North Alabama
Monte
Depending on the car, you could put a looser converter in, to let the motor make rpm, but not lock the converter so early and keep wheel speed down early.
But you also have to be aware of the situation WE got into at Gainesville. It was so cool and the air was so good, that the car was making stupid power, plus it was a decent, but very cool track, making conditions very tough. I did not get enough runs, to be able to calm the car enough, power wise, to get it down on those small tires.
The Pro-Mods also struggled, to get up on the tire, because the starting line was so good, but by 60ft, the track was cold. VERY tough conditions for high HP cars.
Monte
[Re: Monte_Smith]
#862758
11/25/10 03:47 PM
11/25/10 03:47 PM
Quicktree
A looser converter, lets the motor flash a little higher, BEFORE, it grabs the motor. This keeps wheelspeed down early in the run. It may not be much, but on the type cars that I deal with, letting the car roll out that extra split second, before the converter grabs the motor and really puts the power down, can make all the difference. Its all about power management
Monte
thanks what did you guys do down track? what it looked like to me was an initial hook (on some cars) track loose and getting better down track. or just the boost comming in on the turbos thanks for your time Monte
[Re: Quicktree]
#862759
11/25/10 04:26 PM
11/25/10 04:26 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I just thought of a fun little experiment to see who makes the best converters. Could be done kinda like an engine masters thing. Get 5 fairly different proven combos of cars even different brands and have one converter sent from each converter maker for each car then get to racing and swapping converters and see whos run faster on average the first time out Also be fun to do a camshaft competition in a similar format and compare cams from different makers useing their recomendations.
[Re: HotRodDave]
#862760
11/25/10 04:40 PM
11/25/10 04:40 PM
Quicktree
I doubt that would prove which is the best. like Monte said it's a matter of who gets it the closest the first try. there are many quality converters but very few that can take numbers and build a converter thats right the first try. and really there is know way of knowing if it can't be improved on whith an adjustment. it's not an exact science, people usally guess what kind of power and torque they are making or get bad dyno numbers that causes problems.
[Re: KOS]
#862761
11/26/10 07:34 AM
11/26/10 07:34 AM
KOS
Ok guys first let me clarify something.....i never expected one to outperform the other i actually figured the ptc would be slower because it was built tighter.my grievence is a tighter built conv(ptc)has the same amount of slippage the looser built(coan).
Once again i bought the ptc on the pretense that it would work for me as a NOS conv.i spoke with kenny@ptc because i had a choice of 3different 8"ptc verts at the time this one seem to fit the bill for the power adder deal.i guess i should have worded the post a little differently because it wasnt a apples to apples comparison just somewhat dissapointed that the "tight"conv has that much slippage i was expecting btw 4-6%.im thinking of sending the coan to ultimate for a tuneup and maybe the ptc back to kenny for an adjustment.Nick
[Re: sixpackgut]
#862762
11/26/10 08:33 AM
11/26/10 08:33 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
im happy with TCT
3 freakin tenths happy
[Re: HotRodDave]
#862763
11/26/10 10:55 AM
11/26/10 10:55 AM
Posts: 3,138 Central NC
gch
Central NC
I doubt too many converter companies would volunteer for this one.Too much downside for all of them.
I agree on the cam comparison though.IT has been done before but not usually an apples to apples comparison.
[Re: KOS]
#862764
11/26/10 11:59 AM
11/26/10 11:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Once again i bought the ptc on the pretense that it would work for me as a NOS conv.i spoke with [Email]kenny@ptc[/Email] because i had a choice of 3different 8"ptc verts at the time this one seem to fit the bill for the power adder deal.i guess i should have worded the post a little differently because it wasnt a apples to apples comparison just somewhat dissapointed that the "tight"conv has that much slippage i was expecting btw 4-6%.im thinking of sending the coan to ultimate for a tuneup and maybe the ptc back to kenny for an adjustment.Nick
Did you try this conv with the nos to see if it tightened up on slippage... big difference between using nos or not... I'm wondering if using the nos it would decrease the clearance to tighten up the fin clearance due to the added torque and heat
[Re: MR_P_BODY]
#862765
11/26/10 01:38 PM
11/26/10 01:38 PM
Monte_Smith
North Alabama
Ok...Let me start by saying, I don't work at PTC, nor am I a converter expert, but I have sold or given specs for countless nitrous converters. If an 8" converter, was built by PTC, to go behind a stroker big block, I could nearly guarantee, that there was NO mention of any nitrous being put on that motor originally. An 8" converter, is just NOT what you build for a squeezed big block. Now if you talked to Kenny and he suggested that one, based on the 3 choices you had, that just likely means it is the tighest of that group, but not what the car really needed. You can only make an 8" converter so tight.
You need to have a converter, built to YOUR specs, by someone. Again, I don't know Coan policy, but I know PTC will take their own converters in on trade
Monte
[Re: Monte_Smith]
#862766
11/27/10 02:54 AM
11/27/10 02:54 AM
KOS
I am only talking a max of 200hp shot that is why i figured a tight 8"with about 4-6%slip should work.this conv is supposed to be one of their tightest 8"s and works out to be over 10%slip thats why im dissapointed.ive ran dynamic,TA,A-1,ATI and have had good results with all of those and the coan.TCI and PTC so far in my experience no.Monte how much more do you figure a 200shot will push the converter?my thinking is this ptc might be too loose.......
[Re: Monte_Smith]
#862768
11/27/10 04:55 PM
11/27/10 04:55 PM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
Monte
Kenny actually took a Coan 10-blower convertor that he intially repaired and converted to spragless on trade for me a couple of years ago when I changed from Lencodrive to Bruno/Lenco. Don't race as often as most of you guys but its lasted 3 years behind a B/Alky 557 with just a freshen up last year. No complaints with PTC.
[Re: KOS]
#862769
11/27/10 06:08 PM
11/27/10 06:08 PM
Monte_Smith
North Alabama
Not so much the hp of spray you are adding, it is the added torque. Myself, I would never spec an 8" converter for any nitrous combo, unless it was a very small shot, on a very light car.
Monte
