BIG CAM ? #861113
11/23/10 12:05 AM
11/23/10 12:05 AM
E
EJ440 Offline OP
EJ440  Offline OP
E
What would you call a big cam in a -1 headed 500rb @13.1 ?
Re: BIG CAM ? [Re: EJ440] #861114
11/23/10 12:13 AM
11/23/10 12:13 AM
Delray beach, Florida
P
Performance Only Offline
P
anything near .800 lift or bigger. anything much smaller than that is fairly normal.
machine shop owner and engine builder
Re: BIG CAM ? [Re: Performance Only] #861115
11/23/10 12:19 AM
11/23/10 12:19 AM
E
EJ440 Offline OP
EJ440  Offline OP
E
what about @50 ?
Re: BIG CAM ? [Re: EJ440] #861116
11/23/10 12:23 AM
11/23/10 12:23 AM
UK
602heavy Offline
602heavy  Offline
UK
what about @50 ?
.006 would be a better consideration.
Re: BIG CAM ? [Re: Performance Only] #861117
11/23/10 12:48 AM
11/23/10 12:48 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
276/282 should do it!
Re: BIG CAM ? [Re: 602heavy] #861118
11/23/10 12:51 AM
11/23/10 12:51 AM
P
P
what about @50 ?
i agree. the numbers @.05 can be all over the place depending on the lobes used.
Re: BIG CAM ? [Re: EJ440] #861119
11/23/10 03:57 AM
11/23/10 03:57 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think a fairly common size wotld be around 270 @ 0.050", 0.700"+ lift, so I would consider a cam big if it was larger.
I made some compromises with my cam selection (Small 264 duration @ 0.050" cam, 0.715" lift) because of piston to valve clearance issues and I did not want to cut deeper valve reliefs in the pistons.
Re: BIG CAM ? [Re: 602heavy] #861120
11/23/10 04:16 AM
11/23/10 04:16 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Don't you guys know that .050 numbers are the important thing!! LOL Sorry I couldn't help it.I'd think the opening and closing points as well as the design of the lobe makes the output and good track numbers,just how you figure them is the difference between men and boys.I hope for some expert opinions.
