Is it ok to run Dexron 3 with a.......... #860932
11/22/10 09:25 PM
11/22/10 09:25 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
reverse manual valve body in a 727? I can get a deal on this fluid...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Is it ok to run Dexron 3 with a.......... [Re: Boosted] #860933
11/22/10 09:32 PM
11/22/10 09:32 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yep I'll be just fine
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Is it ok to run Dexron 3 with a.......... [Re: dusturbd340W5] #860934
11/22/10 10:09 PM
11/22/10 10:09 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
great... Gonna go get some tomorrow.
2011 RAM3500
Re: Is it ok to run Dexron 3 with a.......... [Re: Boosted] #860935
11/22/10 10:47 PM
11/22/10 10:47 PM
I like and use either type F or type FA in all my street and strip 727 without a trans brake
Re: Is it ok to run Dexron 3 with a.......... [Re: Cab_Burge] #860936
11/22/10 11:18 PM
11/22/10 11:18 PM
Kissimmee Fl.
Kissimmee Fl.
A 727b will run with just about anything in it type F,FA,Dextron II,III ATF+3,4 some guys even use tractor hydraulic fluid never really seen a difference between F or Dextron ot the sny for that fact other than the syn do run a few degrees cooler
