Page 17 of 26 1 2 15 16 17 18 19 25 26
Re: 71 cuda pro touring project [Re: Mad Dart] #860154
10/07/12 12:18 PM
10/07/12 12:18 PM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
I decided to extend the rocker panels and front fenders down 2 1/4 inches. I wanted to get rid of that aweful pinch weld and flat spot on the lower part of the rockers. The result is a more finished look, the car appears lower than it is, and it hides the exhaust and underside much better.
Re: 71 cuda pro touring project [Re: johnscudashop] #860155
10/16/12 01:53 PM
10/16/12 01:53 PM
Mrytle Beach SC
Mrytle Beach SC
Another photo
Re: 71 cuda pro touring project [Re: johnscudashop] #860156
10/16/12 01:54 PM
10/16/12 01:54 PM
Mrytle Beach SC
Mrytle Beach SC
Had to drill some holes in the front fenders to access the lower fender bolts
Re: 71 cuda pro touring project [Re: johnscudashop] #860157
11/01/12 04:53 PM
11/01/12 04:53 PM
Mrytle Beach SC
Mrytle Beach SC
In order to hide the window channel molding I extended the drip rails, I used some 22 gauge steel bent ant a 90 angle then stretched around the drip rail area and welded in.
Re: 71 cuda pro touring project [Re: johnscudashop] #860158
11/01/12 04:54 PM
11/01/12 04:54 PM
Mrytle Beach SC
Mrytle Beach SC
another view of channel
Re: 71 cuda pro touring project [Re: johnscudashop] #860159
11/11/12 11:03 AM
11/11/12 11:03 AM
Mrytle Beach SC
Mrytle Beach SC
Here are sum shots of the car on how it stand today
Re: 71 cuda pro touring project [Re: johnscudashop] #860160
11/11/12 11:04 AM
11/11/12 11:04 AM
Mrytle Beach SC
Mrytle Beach SC
The front
Re: 71 cuda pro touring project [Re: johnscudashop] #860161
12/11/12 07:20 PM
12/11/12 07:20 PM
Mrytle Beach SC
Mrytle Beach SC
Playing around with some more aluminum . Lol
Re: 71 cuda pro touring project [Re: johnscudashop] #860162
12/11/12 07:20 PM
12/11/12 07:20 PM
Mrytle Beach SC
Mrytle Beach SC
Trunk shot
Re: 71 cuda pro touring project [Re: johnscudashop] #860163
12/25/12 08:43 PM
12/25/12 08:43 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Awesome work brotha! Incredible fab skills...Just crazy...
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: 71 cuda pro touring project [Re: mopardude318] #860164
12/29/12 02:10 PM
12/29/12 02:10 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
John....hope you had a nice Christmas. I haven't forgotten you on the back seat. Hopefully the wife & I can sneak a trip down after New Years.
Re: 71 cuda pro touring project [Re: JDMopar] #860165
01/03/13 04:42 PM
01/03/13 04:42 PM
Mrytle Beach SC
Mrytle Beach SC
That sounds great JD, I had to cut out the sheet metal above the mufflers because it was only a 1/2 clearance between the muffler and the floor,so I am gonna have to modify the back seat frame and anchor points anyway.
Re: 71 cuda pro touring project [Re: johnscudashop] #860166
01/03/13 04:46 PM
01/03/13 04:46 PM
Mrytle Beach SC
Mrytle Beach SC
Setting the driveline angle at 1 degree down instead of the standard 3 degree keeps the exhaust closer to the floor and requires floor mods but the benifit of lowering the car another inch or so is worth it.
Re: 71 cuda pro touring project [Re: johnscudashop] #860167
02/08/13 09:51 AM
02/08/13 09:51 AM
Mrytle Beach SC
Mrytle Beach SC
I moved my wheels out, 1 inch on the back and a 1/2 on the front. I need to roll the wheel lips to do that and was gonna do the ole baseball bat and the jack routine but decided to use the eastwood lip tool. It took me a 1/2 a wheelwell and did a nice job.
Re: 71 cuda pro touring project [Re: johnscudashop] #860168
04/19/13 10:27 PM
04/19/13 10:27 PM
Mrytle Beach SC
Mrytle Beach SC
A little more progress. I flush mounted and made my own taillights +bezels . This gets rid of the seam and brings the lenses flush to the surface
Re: 71 cuda pro touring project [Re: johnscudashop] #860169
04/19/13 10:31 PM
04/19/13 10:31 PM
Mrytle Beach SC
Mrytle Beach SC
Taillight lenses fitted to the bezels
Re: 71 cuda pro touring project [Re: johnscudashop] #860170
04/19/13 10:33 PM
04/19/13 10:33 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Sweet, LEDs? Ooooooo.
I can't afford this. mark
Re: 71 cuda pro touring project [Re: a12superbee] #860171
04/28/13 07:51 PM
04/28/13 07:51 PM
Mrytle Beach SC
Mrytle Beach SC
Yes , I am using a Custom LEDs for the tail lights and parking lights
Re: 71 cuda pro touring project [Re: johnscudashop] #860172
05/05/13 04:05 PM
05/05/13 04:05 PM
Mrytle Beach SC
Mrytle Beach SC
I mocked up the hood latch cover today.
Re: 71 cuda pro touring project [Re: johnscudashop] #860173
05/05/13 04:08 PM
05/05/13 04:08 PM
Mrytle Beach SC
Mrytle Beach SC
I wanted to keep the air directed thru the radiator it also closes up that large gap between the radiator support and header panel.I made it from some 6061 aluminum. I plan on adding the hood pop up spring and hood release.
