Re: !!!! Update broke the race car with rearend pics!!!!
[Re: Mopar_Mike]
#859590
11/22/10 04:16 PM
11/22/10 04:16 PM
Guitar Jones
I've broken plenty of 8.75 ring gears but since I went to the aluminum carrier and the pro gear I haven't broken anything. I'm going to put a new pro gear in before the new stroker engine goes in though.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: cgall]
#859592
11/22/10 06:03 PM
11/22/10 06:03 PM
Guitar Jones
I could only get 50-100 runs on a set of street gears, had to pull axles and check ring gear teeth a couple times a year. That will get you by while you save for a Dana, I put a pro gear in my 8-3/4 in 1997 and it's holding up fine. Pro gears are hard to find nowadays, tho.
Strange still sells them, I just ordered one but they only come in one ratio, 4.86:1
[Re: mopar65]
#859593
11/22/10 09:18 PM
11/22/10 09:18 PM
Posts: 16,478 Canada
CrAzYMoPaRGuY
Canada
I don't even see ONE billet cap in this thread?!?! Do you guys just run a stock 8 3/4 rear with a gearset?
CrAzYMoPaRGuY
