Page 3 of 3 1 2 3
Re: Broken Rearend update [Re: Big Squeeze] #855375
11/18/10 12:58 AM
11/18/10 12:58 AM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Something to think about........A LOT of times when parts like that break it's when the car is coming out of the water box and the tires grab and jerk the wheel speed down.......or it's pedaled it after it's started spinning the tires a little bit.......
So how can a driver avoid that? Obviously dont pedal it but what about exiting the burnout?
Re: Broken Rearend update [Re: Pat7272] #855376
11/18/10 01:03 AM
11/18/10 01:03 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
you should never be under power when the tires bite coming out of the water. Drag radials are worse, since they don't slip like slicks they transfer all the shock to the drivetrain and the rear is first. His axles were his weakest link this time........
Drag radial cars need to check the axles pretty regular.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Broken Rearend update [Re: bigtimeauto] #855377
11/18/10 02:10 AM
11/18/10 02:10 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
You aren't supposed to do a burn out in the water box in the first place.
Re: Broken Rearend update [Re: demon440] #855378
11/18/10 10:53 AM
11/18/10 10:53 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
OK.......You roll through the water box, start the burnout where the ground is damp/wet (which is still considered the water box) and as you roll forward you need to make sure to let off the throttle before the tires grab, which means you need to have quite a bit of wheel speed.......
I know it sounds funny, but most of the time it's a lack of power that breaks stuff......there's not enough power being applied to keep the tires spinning so the tires are jerked down to a stop......That quick/sudden stop is what kills parts......I've seen rods kicked out.....torque conveters broken......axles broken.......low/reverse roller clutches exploded........U-joints flying out.......
I'd built a Turbo 350 trans for a customer's low 10 second truck.......They take it out for a test drive and the very first time they hammer on it they break the input shaft (this is on the street)......They think they're the shizzle because it makes so much power but what really happened was is they were blowing the tires off while in low gear and it hooked up, yanking the motor down, and twisting the input shaft........It's that sudden smack that's the killer....... They actually came back to me all pissed off because I "couldn't build a trans to hold their power"......
If you can't handle the truth, you're living a lie.......
Re: Broken Rearend update [Re: Big Squeeze] #855379
11/18/10 11:16 AM
11/18/10 11:16 AM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
Well I can tell you a I didnt pedal the car, especially in the first 50 feet of the run.
I also am very concious on letting off the throttle as I leave the water box, but I do notice the car never really grabs when Im finishing the burnout like my dads car or a dragster does.
Page 3 of 3 1 2 3
