Re: 12 Second combos & what it took to get it?
[Re: greenpigs]
#855072
11/16/10 10:07 AM
11/16/10 10:07 AM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
Very easy and cheap. Just as one simple example, as there are tons more out there that are more highway friendly... '64 Savoy 3775lb street car -74 cast crank 440 pulled out of a land yacht in the junkyard. It had overheated and smelled of burnt oil pretty bad. It still turned over, so we cleaned off the filth & grime, threw in a used .509 cam & lifters, swapped out the springs, Team G intake, 750 DP, $20 swap meet headers of unknown origin, 10" converter, 4.56 gears and a 30x9 slick netted us 12.80's. (No valve job or anything. Lots of miles on the engine.) Freshened up the heads, added a factory Max Wedge intake, 600 AFB carbs and got it down to 12.40's. I'm sure it would have run the same or better without the Max Wedge intake, but we wanted to get into NSS racing. This was back in the early/mid 90's...had all of $200 in the motor minus the Max Wedge stuff since we had extra parts laying around. It would have been quicker yet if we had something better than a TCI Streetfighter converter. Was it an ideal highway cruiser? No. But it was driven everywhere including the highway and it would run on crap gas. Contrary to popular belief, the street manners were fine. It did not run warm, idled in traffic, etc... It's all what you are used to though.
[Re: greenpigs]
#855073
11/16/10 10:25 AM
11/16/10 10:25 AM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
I doesn't take much to get in the 12's with nearly any Mopar. A cam, intake, carb, headers, converter, gear and some small slicks should get just about any car in the 12's as long as the weight to cubic inch ratio isn't stupid, like a 318 in a 4200 pound B body.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#855074
11/16/10 10:33 AM
11/16/10 10:33 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
360 +.030 stock rods, crank, flat top pistons, home ported j's, single plane with 750 dp, TTI's full 2.5" exhaust, small solid 520 lift/ 244 @.050 cam, 3.91 gear, 4K stall, in a 71 demon at 3,460lbs 12.22, at 109.8 mph only time out, needing a jet change.
[Re: greenpigs]
#855075
11/16/10 10:43 AM
11/16/10 10:43 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
what car? pretty easy to make a high 12 second b-body with a 440. My old 67 coronet weighed 3850 and ran 12.90 @ 104 with a 9:1 .030 over 440, cast junk pistons, stock rods, crank, stock 906 heads, stock valve trane, Summit 488 cam, RPM intake Holley 750Dp, Cheap headers, Mopar 175k converter (2600), MP shift kit, and 3.91's. You can do it with 383's and SB's but it will cost you much more. A 10:1 440, with alum heads or ported iron heads, 500+ lift cam, headers, RPM intake 750-850DP, 2800 stall and 3.91's will get a 3800lb B-body into the mid 12's easy. In an A-body you'll be in the 11's.
[Re: greenpigs]
#855076
11/16/10 10:55 AM
11/16/10 10:55 AM
Posts: 447 NJ
JCCuda
NJ
My 360 started as a .040 over Napa rebuilt short block. I took it apart to check everything. I had the block decked (deck .015 head 63cc., gasket .028, compression 10.51)reversed the cast dished pistons on the rods and put in good rod bolts and had the rods resized. I put in an old Manley cam that I had. 443 lift 224@.050 I don't remember the lobe seperation but I think it was around 108. I used J heads pocket ported with 2.02 int. valves and 273 adj. rockers an LD340 intake with a 1" 4 hole spacer and a Vac. 750. For exhaust I used heddmen 1 5/8" headers, 3" exhaust with ultra flows ending at the axel. I used a 904 with a Dayco 2,400 stall converter and an 8 3/4 with 3.91's the slicks were 8"x 26"x 14". Suspension consisted of 6yl. bars and comp. eng. adj. shocks in the front and 002/003 superstock springs with Mopar perf. 50/50 xtra long shock in the rear. The car was a 70 Valiant 4 door it weighed 3,320 with me in it. With an electric water pump drive, 5/16" fuel line with holley mech. fuel pump and a homemade fresh air intake (dryer hose and a dual snorkle air cleaner)the best run was 11.96/113 but it typically went 0's and teen's in decent air at Atco and E-Town. Typical 60'was low 1.70's. With a looser converter maybe around 3,500 stall it probably would have gone 11.70's or 80's.
[Re: JCCuda]
#855077
11/16/10 10:59 AM
11/16/10 10:59 AM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
My old set up was stock rods, speed-pro pistons 9.5-1 stock heads .508 mopar cam performer intake went 12.88 best with a 360. now i have x headed 360 with eagle rods kb pistons m-1 single plane 750 dp .525 525 hydro cam from comp 4200 stall with 4.10's and 28" tall tires. only thing i changed was the motors.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: greenpigs]
#855079
11/16/10 11:35 AM
11/16/10 11:35 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I went high 11s w/ a VERY mild 440 combo. 3700# '70 cuda w/ SS springs, 3.91 gear, and 26x10 slicks. Full interior, full 3" exhaust w/ tailpipes and factory cuda tips. '71 440 HP shortblock, bored .040" over. Ross flattop pistons (close to 10:1 compression). Factory forged crank and the original 6 pack rods. Stock oiling system w/ factory pan. 906 heads...nothing but a 3 angle valve job. Even reused the factory valves...NO porting. 509/292 MP purpleshaft cam, stock rockers and pushrods. Edelbrock Performer RPM intake, 830 holley double pumper. 1 7/8" headers, 3" exhaust w/ 2 chamber flowmasters. 727 w/ a TCI 10" Streetfighter 3500 stall. This combo ran on pump gas and went 11.80s at 112 mph, 7.50s in the 1/8, 1.67-1.69 sixty foots. Not to mention I put a LOT of street miles on it. This motor is currently in my dad's '69 road runner only now it has a six pack setup on it, a 4 speed, and 3.55 gears. Hella fun to drive!
[Re: kissmyaspen]
#855080
11/16/10 11:43 AM
11/16/10 11:43 AM
Posts: 147 Milledgeville, (central) Georg...
Bighead440
2 cheep bulletproof combos: 1) '71 Demon 3100# 3.91 gears, 904 trans, 3000 stall. 360+.030" KB107 pistons, stock crank and rods. J-heads, 2.02x1.60 valves, Crane springs& retainers. ZERO port work. MP .528" solid cam kit, 273 pushrods&rockers. TorkerII, later Perf RPM Air Gap intake, 750 AED DP. 6400rpm shift point. 1 5/8" Hedman Hedders, 2.5" exhaust w/FlowTec Afterburner mufflers. 12.50s@109mph in the heat. 17" vacuum at idle, drive anywhere, loved it! 2) '67 Coronet 3600# 3.91 gears, 727 trans, 2300 stall (stock 318/727 hi-stall from a D-250). Junkyard '71 Imperial 440, freshened but standard. Stock 906 heads, Crane springs&retainers. ZERO port work. Used MP .474" Hemi grind cam kit, stock rockers and pushrods. Performer RPM intake, 750 Eddy carb. Hedman 1 3/4 Hedders, 2.5" exhaust with Flowmaster 40s. 12.50s @110+mph in the heat. Good manners, sounded mean and rock solid performance for the dollar. 5400rpm shift point, live forever!!! RB
[Re: HoosierGTX]
#855082
11/16/10 01:08 PM
11/16/10 01:08 PM
Mr.Yuck
Brookeville, Md
This is a great topic,I am putting together a 68 440 for my 65 Coronet,my plans are for, 68 440 block that has already been bored .40 used MP 509 cam cast flat top pistons fresh stock 906 heads with good springs Melling pump and a windage tray 10" street fighter SS springs and 391's
Any advice on a carb,intake and ignition setup would be greatly appreciated.
you better have cut your heads or your block. Most cast pistons are way down in the hole and that 509 hates low compresson. Try a different cam.
[Re: Mr.Yuck]
#855083
11/16/10 01:57 PM
11/16/10 01:57 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Not here. Paid $600 for my 340 engine, tore it down, replaced the rings and bearings and put it back together. Still has the factory rods with good bolts, and the original X heads. Added a Comp XE274 hydraulic cam, an Airgap intake, a 650 Holley, PTC 3,500 converter, SS springs, 3.91 gears. Ran 12.91 @ 103 mph with less than $2,000 invested in the engine. Car is heavy for an A-body too.
[Re: DJVCuda]
#855085
11/16/10 02:15 PM
11/16/10 02:15 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
The 72 runs high 12's with a 360.
Motor started out as a MP crate engine then had OOTB eddy heads an a vodoo cam installed.
Trans is a stock 727 with a TCI VB and 11" conv. Running 3.91 gears and it weighs around 3400#'s
Could probably sneak a little more out of it if we were to go with something like the 10" Street fighter conv.
[Re: dustergirl340]
#855086
11/16/10 02:33 PM
11/16/10 02:33 PM
Mr.Yuck
Brookeville, Md
I meant in a B-body
[Re: Shaker223]
#855088
11/16/10 04:15 PM
11/16/10 04:15 PM
Bighead440
.060 over 383, 3 angle valve grind on mildly ported 516 heads, 9.4:1 comp., silvolite pistons & iron rings, MP484 cam, thermoquad. 3500lb 66 coronet station wagon. 4.43 gear, 3000rpm convertor. 12.50's @ 109mph
I LOVE that!!! We did a 4spd '68 Roadrunner with a bone stock '70 383 shortblock, stock 906s, MP 509, stock rockers and Hemi springs, TM-6 intake, 750 Holley with the ProForm center (830cfm???), 1 3/4" headers, Herb McCandless clutch and 4.30s. It ran 12.50s@108 on 27" Hoosier cheater slicks!!! Do NOT rule out the 383 for anything fun!!!
[Re: greenpigs]
#855089
11/16/10 05:26 PM
11/16/10 05:26 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
Hey Guys! It took me a lot more money and parts to get into the 12s than most on here, but I will share anyway. 69 Super Bee 3950lbs (with me and a passenger on my best run) 383 - 11:1 3.91 3500 converter 232/242 solid cam RPM intake + 750DP Edelbrock Heads 1 7/8 headers Ran 12.7 @ 109 on 28" ET Streets the only time I've been to the track with this combo. Same combo minus the Edelbrock heads went 13.40s
Paul '69 Super Bee 383 EFI Turbo
[Re: Black_Bee]
#855090
11/16/10 05:59 PM
11/16/10 05:59 PM
Posts: 528 N.W. Indiana
DblOJoe
N.W. Indiana
My cheap combo used .030 over 383 block that sat with water in the bores with rust pits used flat top Kb pistons, stock rods and crank 70cc eddy heads 5200 converter with 4.88 gears Car weighs 3240 with me in it 11.31 @ 117 oops you were looking for 12's sorry
[Re: Black_Bee]
#855091
11/16/10 07:03 PM
11/16/10 07:03 PM
Posts: 1,805 ky hills
thehemikid
ky hills
...Fwiw 14yrs ago ...62 Dodge (lighter B-body) ...3220-40 lbs (no back seat, race fronts seats),w/o driver ...452 cid 8.4 cr (.100"+ in the hole) forged. ...stock crank,& rods ...346 completely stock heads ...460 lift PAW cam ...Torquer intake ...800 Holley ...MSD 6AL ...1-7/8 fender wells ...4200 GER converter ...manual V/B pushbutton ...4.30 gear, 28 x 9 slick ...stock rear leafs w/ 2 clamp's per front segments, & a snuber ...7.82 et 1/8th that ='s ~ 12.20's in 1/4 ...300 hp shot of N2O = 6.92 1/8th (with dancing main caps)
___changes to motor ...509 cam ...Crane rockers (1.5 off my shelf) ...electric water pump ...Hoosier 28 x 11.5 QTP ...7.57 et 1/8th ='s ~ 11.80's in 1/4
...EDIT: (Crane)
What cam would you recommend?
[Re: Mr.Yuck]
#855092
11/16/10 07:27 PM
11/16/10 07:27 PM
Posts: 150 Seymour,IN.
HoosierGTX
Seymour,IN.
[Re: Mr.Yuck]
#855093
11/16/10 07:47 PM
11/16/10 07:47 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I meant in a B-body
Not here either!! STOCK OEM 383 shortblock,906's cut -.030,old Mopar street hemi grind cam, double roller chain,933 Mopar springs,valve job, TM-6 ,Holley 750 DP,Accel BEI ignition,1 7/8ths Hooker headers,4.10 gear 28" tire and 4-speed with Zoom clutch,ran 12.70's all day with M&H Muscclecar tires.Dad would hook the mufflers back up Sunday and drive to work M-F.
[Re: Chris2581]
#855094
11/17/10 05:49 AM
11/17/10 05:49 AM
Posts: 1,153 Adrian, Mi
pro6pakRR
mopar addict
mopar addict
Adrian, Mi
My 12.48@108 combo,bone stock 71 440HP with a 533 hyd mopar cam,stock rockers.Stock 6 pack,8in ptc conv,727,4.10 dana,in a 3895lb 70 Roadrunner.Still have that engine sitting in the barn as a back up if my 11.50@117 engine brakes.
[Re: BSB67]
#855096
11/18/10 10:14 AM
11/18/10 10:14 AM
Posts: 198 Gainesville Fl
mphsmitch
Gainesville Fl
My combo for my 90 dakota is pretty simple. 96 360 magnum 2.02 R/T heads with a little goldmember porting pro products intake 750 D/P with choke horn cut off .228 @.50 .488 lift? cam 727 w/ manual valve body 9.5 PTC converter 3.73s 325/50/15 drag radials on loan from goldmember I took it to the track last night for the last wed. night test and tune and the conditions were very good. R/T .037 60' 1.727 330 4.974 1/8 7.748 mph 87.84 1000 10.18 1/4 12.275 mph 107.44 The truck weighs 3500lbs with me in it.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
[Re: StealthWedge67]
#855098
11/18/10 08:57 PM
11/18/10 08:57 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
- 4275 lbs (at that time) - 3.23 - 2.25" compression bent exhaust - No headers - Stock 12" converter (1800 rpm) - P225 70 14 tires - .030 over 440 - Ported heads 915s - 6 Pack - .455" MP cam
12.80s @ 108 mph
Wanna come tune my car?!
Funny you said that, as I was going to add that the results were after tuning, adjusting and changing stuff for a few years and probably 150+ passes at test and tune.
I have helped others and enjoy that as much as anything.
[Re: BSB67]
#855099
11/18/10 09:29 PM
11/18/10 09:29 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
My combo is: 1972 340+.30, KB pistons,stock rods resized for arp bolts,484 purple shaft,eddy ootb open chamber heads,air gap manifold,750 vaccuum holley, getting fresh air from the six pac hood scoop,tti headers flowing through flowmasters all the way out to the tips,727 trans with manual valve body-and coan 3000 convertor. 8 3/4 rear with 3.73 gears with super stock springs and 11" drums. All in a 69 Dart weighing around 3200 without driver. Car has all original equipment intact. Best yet is 12.59 but usually in the 12.7-12.9 range and street driven.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
#855100
11/18/10 09:29 PM
11/18/10 09:29 PM
Posts: 535 Ohio
racerAL
Ohio
heres a bit of a different one.. -early 70's RV 413 (stock bottom end maybe 8.25-1) -MP 484 cam -M1 intake w/ 750 carb -ported 906's -10inch converter (using trans brake) -4.10 gears (29x9 slick) -36xx lbs. - 12.70's @ 108 mph. -heres a pic of the beast ..lol..amazing what we'll do to go racing aint it.. [image] [/image]
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: racerAL]
#855101
11/18/10 10:21 PM
11/18/10 10:21 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Well, I've apparently got way to much into my motor to be as slow as it is, but here's my entire combo that has gone 12.39 @ 110.
1967 Plymouth Satellite, Full interior, 3770 lbs with me in it. 400 block, .040 over Forged 413 RB crank, (452 cubes) Scat H-beam Rods KB Icon forged pistons - 10.25:1 Mahle plasma-moly rings (bobweight: 2314) MP windage tray OTB Stealth heads with 10* locks & retainers, & Engle double valve springs (350 lb. open) Engle KV-3 solid flat tappet cam: square 252* @.050; .573 lift; 109* cl, installed straight up. Performer RPM intake Holley 830 cfm DP jetted 78f 84r MSD Digital 6+ ignition w/ Mallory Mag-breakerless distributor - 36* total in at 3k. Hooker Comp 1-7/8" headers to 3" dumps, down to 2-1/4" full exhaust with Flowmaster 40's ACC 10" 3500 rpm converter 727 with Transgo Stage 2 kit 8-3/4" w/ 3.91:1 gears; sure grip. Stock suspension with SSM lift bars, and Summit adjustable shocks CE bolt in Frame connectors, welded in. Hand-me-down 28x9x14 slicks mounted on 14x6 rims.
I've made 10 passes and haven't really done anything except mess with the jetting a little. I love the car, and am proud of the motor I built for right at 5-grand total. I am plenty confident that there's more in it, But I'm frustrated with what I see here..... i.e.: a lot of guys going WAY faster than me, with way less motor. I think that a set of better tires on the right rims will help a little, as its pretty skatey on the current slicks.
I think my combo SHOULD be somewhere near the 11.70's. I figure I'll have to make about 114mph to get there though.
#855102
11/18/10 10:30 PM
11/18/10 10:30 PM
StealthWedge67
Puyallup, WA
Here's what it looks like under the hood. (pretty stealth)
#855103
11/18/10 10:34 PM
11/18/10 10:34 PM
StealthWedge67
Puyallup, WA
And in the pits at Pacific, with my Dad.
[Re: SILVER67]
#855105
11/19/10 01:23 AM
11/19/10 01:23 AM
Posts: 707 California
BigDaddy440
California
Running 12's with a big block, especially a 440 doesn't take too much work.
My very first 440 car was a 1968 Coronet R/T. I took the stock 440, rebuilt it and only added a MP 484 lift cam, aftermarket intake, holley carb, and headers. With the stock 3.23 gears, I was running 13.3-13.4 & 103-104 mph in a full weight car.
Wanting to get into the 12s, I had the heads bowl blended (mild port job) and added 2.14 / 1.81 valves and changed the camshaft to something a tad bigger, I think it was the MP .509 lift cam. Same intake, carb, and exhaust. I did add 3.91 gears. Next run out, 12.49 @ 108 mph.
Finally, I dropped on some Edelbrock Heads, a Solid Tappet cam from Hughes and crane roller rockers. I also removed the stock steel hood, and added a year one fiberglass six pack hood to save some weight and look aggressive. I moved the battery to the trunk as well. I ran a 11.9 @ 114.5 mph the next time out. 60 ft times were 1.75.
-dan
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#855108
11/19/10 03:37 AM
11/19/10 03:37 AM
Posts: 2,379 MD
Kevins493
MD
My old '64 Fury: 440 .040 over, stock crank, 440source rods (I didn't have any good LY's at the time), true 10.03:1 compression, .509 cam in at 4* advanced, home ported 346 heads that I did when i was 16 using the MP templates and blending the bowl into the runner... eddy rpm and holley 850 dp, stock electronic ignition with orange box, 1 3/4 hedman's with homemade 3" exhaust with flowmaster-type mufflers ending before the axle.. 4200 flash 9.5" ptc, 3.91's and 275 drag radials. 3525lb with driver....11.74@114 through the mufflers on pump gas.
[Re: 383man]
#855111
11/19/10 04:05 AM
11/19/10 04:05 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
1970 Cuda 340 4/spd 4:30 gears
Stock short block and cyl heads GK hyd cam .540 lift and springs/retainers Edelbrock dual plane and 750 Holley DP Hooker comp headers-0pen Curved stock distr. M&H 8 in slicks.
12.92/105-Windsor Dragway 1971
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#855112
11/19/10 07:51 AM
11/19/10 07:51 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
3650 lb car Stroked 318/390 - inc Eagle crank, KB slugs. Then ported cast 587 heads - 2.02 valve also XS282S cam 3.89 gears / 27" tyre/ 904 trans TQ / LD340 12.6 @ 108.7 mph - 1.85 60 ft. 2 issues - Uncool tyres - a 60ft you wouldn't take home to meet your mother..... and, ......now running an M1 SP making 30 RWHP more than the LD340....so maybe 12.2-12.4 now?
#855113
11/19/10 04:13 PM
11/19/10 04:13 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
You and I almost have the same set up. This is what I have and my best is an 11.80 @ 113(and change), 1.62 60', .452 r/t.
I got a 67 Coronet, all steel, full interior. 400 stroked to 470, 10.8:1, Diamond pistons, Manley Rods, 727 trans with a 2800 PTC, 4.10 dana spool, Eddy RPM heads OOTB, RPM intake, 830 Quik Fuel carb, Voodoo cam 60304, MSD, 325x50x15's M/T drag radials, TTI 1 7/8" primaries, 3" to rear bumper, summit 90/10's front, stock shocks rear, frame connectors welded in.
You should easily be in the verrrrry low 12's to high 11's with your car before tuning it. I didn't do much to get out of a 12.10 @ 110ish to my new best - basically put on better tires, shocks, and had my trans rebuilt (it definitely had seen it's day) and that was it. I was doing backflips for hours after hitting my first 11 second 1/4. And then the fun began...
The only thing I could think of would be the tires - you said hand me downs... I improved quite a bit with more footprint from a 275 to the 325s I have now... but that also meant I mini tubbed and moved the springs in. How are your 60' times? Spinning? Traction issues? Take photos or a video of your launches to see how your car reacts? I'll be the first to admit, I am always learning AND, what I have learned, I am willing to shed some insight as well. That's what makes Moparts so awesome.
Best of luck to you and your project!!
[Re: greenpigs]
#855115
11/23/10 10:43 PM
11/23/10 10:43 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
68 Satellite, all steel, full interior, heater, wipers, etc, flat hood.
4.10's SS springs M/T 29.5 X 10.5 slicks factory 360 "high stall" converter with the weight knocked off 1 3/4" headers re-ringed 1968 440 short block, std bore, OE pistons 346 heads, valve job, new guides, OE valves, NO porting of any kind, milled .010, steel shim gasket std Performer, 3310 carb Crower 271HDP cam stock rockers, non-adjustable pushrods, single springs, stock retainers
went 12.30's-40's like clock work, 109-110. shift at 52-5300, through the lights around 5500.
swapped to an old Torker intake, blocked the heat x-over, 1" open spacer, swapped out stock lower pulley for Moroso under drive pulley, cut oil pump spring to lower WOT oil pressure from 85 down to like 55-60. went a best of 12.12 @ 112 like that.
oh, and i pretty much always ran it with open headers.
[Re: fast68plymouth]
#855116
11/23/10 11:01 PM
11/23/10 11:01 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
1969 Roadrunner 3700# with driver
446 with 516 home ported heads and big valves, TRW flat tops 10.5:1 compression. Torker Intake, Holley 850 DP, 509 cam, stock alternator, water pump, and big solid steel fan, 1.75 headers, 3500 stall dynamic, 727 manual VB, 3.23 gears, MT 29 x 12.5 Sportsman Pro's.
12.45 @ 111 at 4000ft DA, drove it to and from the track on 91 octane.
[Re: moparmanjames]
#855117
11/24/10 01:16 AM
11/24/10 01:16 AM
Posts: 1,532 crisfield, maryland 21817
82ramIndy493
Want to hear cheap. I built a 71 440 from a Chrysler 300 that had out of round cylinders, one in particular was .017 out. The owner was cheap and didn't want to bore it. I tanked the block, put in new cam bushings, cleaned up the crank, rods and pistons, put everything back as is with new rings, bearings etc., put in a used 484 cam I had sitting around from a previous engine, had the heads milled .040 to bring compression up from the factory 9 to 1., installed a used eddy performer with a 750 holley. rebuilt 727 with a 3000 converter and 3.91 gears in his 71 Charger which has a worn out suspension. The engine is now 10 years old and has excessive wear on # 2 cyl and the engine smokes on that bank but he is happy with it and it is still going. He drives it 40 miles to the track and back home and it runs consistent 12.70s at 106 mph. This is on an engine 10 yrs old with 70 percent leakdown on # 2 cyl. Imagine what it could run rebored with fresh heads and balanced. This is proof it doesn't take much to get a mopar running.
[Re: 82ramIndy493]
#855118
11/27/10 09:58 PM
11/27/10 09:58 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
'66 Belvedere 3,920 race weight Stock stroke 440, 10.9 to 1 Stock 915 heads with Crane 1.5 rockers 1 3/4" headers .550ish lift solid with about 252*@.050 camshaft Torker intake, 750 Holley 727 had a reverse pattern manual valve body and deep pan Dynamic 9.5" converter that would flash 5,500 (I'd shift @ 6,400) 3.54 Dana 60, 28X9 slicks Went a best of 11.65 @ 115 with exhaust dumps open..........Usually ran 11.90's-12.0's @ 112 through the mufflers.......pulling both front tires off the ground about 2".......
If you can't handle the truth, you're living a lie.......
