340 Built #852480
11/13/10 12:01 PM
11/13/10 12:01 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
I have a 340 that has been bored 40 over and is about 2 over the 40. To clean the wall's I'll have about 43 over total. What piston's would be good with that amount of clearance. I was thinking maybe KB's Need lots of opinions.The other question is that the lifter bores have bronze bushings in so can I use normal hydralic lifters.
Thanks Moparts
Re: 340 Built [Re: 72 RR DUDE] #852481
11/13/10 12:50 PM
11/13/10 12:50 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sounds like it time for sleeves or another block to me.
Re: 340 Built [Re: Challenger 1] #852482
11/13/10 01:54 PM
11/13/10 01:54 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
have it sonic checked first
Re: 340 Built [Re: ScottSmith_Harms] #852483
11/13/10 04:12 PM
11/13/10 04:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sounds like pretty spooky territory to me, especially if you plan on making some power with it. Definitely sonic-test the thing and hope for at least .200 on the walls. Pistons & rings might be tough or expensive to find for 4.08-ish.
Re: 340 Built [Re: topside] #852484
11/13/10 04:18 PM
11/13/10 04:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
200 would be awesome but already at .040 over I'll doubt you'll see that. For a street build I'd feel ok with around 150 thick on the thrust sides. You might get a surprise on the sonic check, I have 2 examples of STANDARD bore 340 blocks that only had .080 thick walls on 1 thrust side bore, the other 7 were normal and around 200!
Re: 340 Built [Re: ScottSmith_Harms] #852485
11/13/10 04:25 PM
11/13/10 04:25 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yep need to have it sonic checked I have seen a few that where ok at a .060 overbore.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 340 Built [Re: 72 RR DUDE] #852486
11/13/10 04:27 PM
11/13/10 04:27 PM
As said sonic check it & .043" over doesn't sound too bad & it might be OK going 60 over if you have to (did I say sonic check) or might have to go w some forged pistons if you stay w 40 over (as you know the less over the better). Some pistons their spec has the clearance built in but you know your actual bore size that it will clean up to (including honing I am assuming) so find a piston that will work w that.
Re: 340 Built [Re: ScottSmith_Harms] #852487
11/13/10 04:30 PM
11/13/10 04:30 PM
Hamburg, Pa.
Hamburg, Pa.
I'm not looking to make tons of horse power. It is the original block and I just want to cam it up alittle over stock and use J heads. Just don't know if I can find pistons to use and if the lifter bores with the bronze bushings can use hydralic lifters.
Re: 340 Built [Re: 72 RR DUDE] #852488
11/13/10 05:07 PM
11/13/10 05:07 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
If it were mine and it was already at .040 over, I'd sleeve all 8 back to standard and move on,,,,just my
Re: 340 Built [Re: gtx6970] #852489
11/13/10 05:32 PM
11/13/10 05:32 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Finding decent pistons at 60 over will be tough if not impossible. If it's a numbers block, sleeve it. $80/sleeve is the going rate.
The lifter bushings were probably installed for a hydraulic roller cam. The condition illustrated here shows why:
http://www.hughesengines.com/Index/produ...mp;partid=25802
Should be okay for use with a flat tappet. Someone spent a lot of money on that block.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 340 Built [Re: gtx6970] #852490
11/13/10 05:34 PM
11/13/10 05:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I hear you Bill but along those lines, it's a $800 job to sleeve all 8.
I'd be more prone to find another block (regardless of how it sonics) and build a different engine, or even a 360 (cheaper on average and looks identical) then bag and tag the numbers matching block and stash it for safe keeping.
Re: 340 Built [Re: 72 RR DUDE] #852491
03/05/11 10:37 AM
03/05/11 10:37 AM
Burbank Ca
bkilby Offline
bkilby  Offline
Burbank Ca
Boy I'm glad I found this thread. I just pulled the original 340 out of my Challenger today to take a peek inside. It was supposedly rebuilt in 2006 when the car was restored but I was having some issues with it. Anyhow, I found the 340 bored .040 over like 72 RR Dude and came here to find out what the max bore size that's safe. Thanks to this thread, I know what I need to do.
Besides being .040 over, the cylinder walls are scarred and the crank is .010/.010 and scarred as well. I don't think they did a very good job on the rebuild. What a shame. I think I'll probably have the block and heads checked and verify they're not cracked etc and store the engine away for future use and just buy a crate motor. Hmmm... which one to get...
'73 340 Challenger and then some.
