Page 3 of 3 1 2 3
Re: Dim and Bright lights in the dash [Re: BDW] #850900
11/15/10 10:54 AM
11/15/10 10:54 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I tucked my solid state voltage regulator, headlight relays and a accessory fuse panel under my battery. There is also room for the ECU, but I have converted to HEI on my 65 b-body.
Re: Dim and Bright lights in the dash [Re: convx4] #850901
11/15/10 10:56 AM
11/15/10 10:56 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
One with the ECU.
Re: Dim and Bright lights in the dash [Re: convx4] #850902
11/15/10 03:55 PM
11/15/10 03:55 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Sorry guys, I just cannot agree with "putting stuff under the battery."
That area ON A DRIVER is subject to a lot of road splash and grime, and on something that really does get driven, gets a certain amount of possible acid damage.
Also, having something like ignition under there makes things VERY difficult to troubleshoot
I do realize, you are trying to keep things clean looking, but for me, it's far more important that things work.
Re: Dim and Bright lights in the dash [Re: BDW] #850903
11/15/10 09:48 PM
11/15/10 09:48 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
that is cool the way you did that
Re: Dim and Bright lights in the dash [Re: cornet684me] #850904
11/15/10 11:29 PM
11/15/10 11:29 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I made the accessory fuse panel store under the battery but flip out when needed.
Page 3 of 3 1 2 3
