Crank pulley holes don't line up. #85085
07/07/08 03:09 AM
07/07/08 03:09 AM
KS
MoparKansas Offline OP
KS
I am putting a two groove crank pulley on my motor and one of the holes doesn't line up. Can I just drill the one out that isn't lining up correctly? Is the pattern different on these from year to year?
Re: Crank pulley holes don't line up. [Re: MoparKansas] #85086
07/07/08 03:59 AM
07/07/08 03:59 AM
CA
66Dodge Offline
super gas
66Dodge  Offline
super gas
CA
I had a similar situation when I purchased an underdrive crank pulley for my '66 383. Some dampers had a bolt pattern where all six holes were evenly separated "symetric" and others were "asymetric". My crank dampner was asymetric and my new pulley was symetric.
What I did was overlay the new pulley over the original pulley and rotated them until all holes lined up except for one. At that spot I elongated the hole (in the new pulley)
so that the last bolt will go through.
Re: Crank pulley holes don't line up. [Re: 66Dodge] #85087
07/07/08 06:26 AM
07/07/08 06:26 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
As said just file the hole a bit.My March pulleys have one hole elongated from factory to compensate.Rocky
Chrysler Firepower
Re: Crank pulley holes don't line up. [Re: 66Dodge] #85088
07/07/08 07:20 AM
07/07/08 07:20 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
They changed the pulley bolt configuration in the early 70's?. Not a big deal - file it out. It is only one that is off.
