Popping coming from my 8-3/4"
#84994
07/06/08 09:27 PM
07/06/08 09:27 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
My 8-3/4" was rebuilt a year ago with all new bearings, seals, and a new clutch style sure-grip unit. It gives me a pretty heavy popping sound that you can feel when coming out of a slow speed tight corner. It never does it on a straightaway. At first I assumed it was the tight new sure grip unit struggling a little to slip around the corner. It also will turn over the inside tire a little bit on tight turns. But, its been a year or so now (approx. 2500 mi.) and its still making this noise. Could something be wrong in there? or is this normal? It was set up by a pro and I'd take it back to him, but it was a used gear-set and he said he wouldn't warranty it because of that. I may still end up taking it to him to check out, but what do you guys think of this....
Re: Popping coming from my 8-3/4"
[Re: StealthWedge67]
#84995
07/06/08 09:29 PM
07/06/08 09:29 PM
are you using the GM hypoid additive?
#84996
07/06/08 09:53 PM
07/06/08 09:53 PM
Posts: 6,516 Santa Cruz, California
Lefty
I'm pretty sure the sound is the clutches sticking instead of slipping. I think it will grind itself to death without the correct sure-grip additive.
[Re: Lefty]
#84997
07/06/08 10:32 PM
07/06/08 10:32 PM
StealthWedge67
Puyallup, WA
I'm using the Ford limited slip additive. Should I drain it & refill with fresh gear-oil & additive?
#84998
07/06/08 11:46 PM
07/06/08 11:46 PM
fords additive plain sucks. damage is already done IMO. time to tear it apart.
#84999
07/08/08 11:30 AM
07/08/08 11:30 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I use Posi-X fluid from the major parts chain.
I had this problem before and all I did was jack up the pass side of the axle only. open the fill plug and dump another tube of additive in it.
All good now.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
#85000
07/08/08 11:33 AM
07/08/08 11:33 AM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
Actually Ford's additive is highly regarded. Its been a good choice for MANY years!
[Re: CJK440]
#85001
07/08/08 11:38 AM
07/08/08 11:38 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
I had better results with that stuff than the Ford additive.
[Re: DoctorDiff]
#85004
07/08/08 12:41 PM
07/08/08 12:41 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
That is a common problem. New, off-the-shelf clutch sure-grips are rarely assembled correctly. If a fresh change of gear lube and friction modifier doesn't do the trick, I would disassemble the unit, clean everyting then de-burr the casting around the clutch ears if needed. Be sure to pre-lube the clutch plates with straight friction modifier on assembly.
I prefer Ford friction modifier because it is actually rebranded OEM Spicer stuff.
how about the GM syntho stuff (w/ modifier)? That's what I just put in my unit.
[Re: DoctorDiff]
#85006
07/08/08 09:44 PM
07/08/08 09:44 PM
StealthWedge67
Puyallup, WA
Well, I'll try draining as much as I can out of it, then refilling it and adding another bottle of friction modifier. I'll report back when I get this done. Thanks guys (except the guy who wants me to rebuild it already. For gods sake, man.... I'm glad you don't have my credit card!)
#85007
07/08/08 10:01 PM
07/08/08 10:01 PM
yah 2500miles still making noises, and you think a fluid change is the cure.
#85010
07/09/08 03:10 PM
07/09/08 03:10 PM
Pacnorthcuda
I would follow DoctorDiffs advice any day.
[Re: Pacnorthcuda]
#85013
07/09/08 06:34 PM
07/09/08 06:34 PM
good for you
Re: Popping coming from my 8-3/4"****update******
#85014
10/21/08 09:43 PM
10/21/08 09:43 PM
StealthWedge67
Puyallup, WA
Just donned on me the other day that I never hear that popping sound anymore. draining and refilling with Napa friction modifier (as opposed to ford motorsport the first time) was all I did. It didn't stop immediately, but some months later now, & I can't remember the last time I heard it.
[Re: Mr.Yuck]
#85018
10/22/08 01:04 PM
10/22/08 01:04 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
You have a broken tooth or teeth on the ring gear
Zing! Reading is a lost art...
[Re: 69Cuda340S]
#85019
10/22/08 01:08 PM
10/22/08 01:08 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Long time ago when mine got noisy I did slow figure 8s (to work the lude into the clutches) in the parking lot after I put the additive in. Worked for me.
This was on a One ton chevy with a Dana.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#85020
10/22/08 05:36 PM
10/22/08 05:36 PM
I have an 8 3/4 rear right like yours but with 410 gears. Mine did the same exact thing yours is doing. I put a bottle of the mopar snake oil additive in it and it totally stopped doing it.I would try it before tearing it apart.
Thanks Moparts
