360 connecting rod question #848570
11/08/10 12:11 AM
11/08/10 12:11 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Two questions. I purchased a set of reconditioned rods for a 1974 360. I noticed that the piston end had a bushing so I assumed they were from a 340. The 360 uses a pressed pin so if the bushings were pressed out will the pins from the 360 fit the rods? My second question is since this engine is externally balanced and I wanted to have the rotating assembly re-balanced. Do I need to bring the harmonic balancer and the converter in with the crank, rods & pistons to have this done? Thanks, Gerry.
Re: 360 connecting rod question [Re: GKMOPAR] #848571
11/08/10 12:16 AM
11/08/10 12:16 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I have had some 360 rods bushed and the rod end was opened up for the bushings. For the balance job, balancer, crank, pistons, rods and flexplate. You then run a neutral balanced converter.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: 360 connecting rod question [Re: GKMOPAR] #848572
11/08/10 12:20 AM
11/08/10 12:20 AM
The 360 uses a pressed pin so if the bushings were pressed out will the pins from the 360 fit the rods? Do I need to bring the harmonic balancer and the converter in
(1) no as they bore the pin ID out then press in the bushing as all SB pin dia's are the same and they are only changing the contact from steel to steel to bronze to steel. If re externally balancing yes plus the flex plate.
Re: 360 connecting rod question [Re: RapidRobert] #848573
11/08/10 10:21 AM
11/08/10 10:21 AM
scratchnfotraction Offline
mic the bushing
it could be bushed for floating pins
Re: 360 connecting rod question [Re: scratchnfotraction] #848574
11/10/10 02:24 PM
11/10/10 02:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Also if they are floating pins you need to make sure you have grooves for snap rings in the pistons or else the pin will slide out and trash the bores very fast.
