Race 65 727 How much goes in the trash can #847605
11/06/10 09:26 PM
11/06/10 09:26 PM
Phila Pa
scatpacktom Offline OP
Phila Pa
I bought a core 65 cable trans for my 64 Sport Fury. I'd like to know how much goes in the trash? I know the input and front pump splines are different. What else won't I be using?
Re: Race 65 727 How much goes in the trash can [Re: scatpacktom] #847606
11/06/10 10:12 PM
11/06/10 10:12 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Just get the pump, forward an wide bushing direct drum out of a later model and put it in.......then a billet rear servo, HD band strut, good valve body and a deep pan and you're good to go.......
If you can't handle the truth, you're living a lie.......
Re: Race 65 727 How much goes in the trash can [Re: Big Squeeze] #847607
11/06/10 10:36 PM
11/06/10 10:36 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You need to replace the input shaft and reaction support in order to use late model converters. If you would like to use the wide bushing then get the front drum with the matching wide bushing reaction support. I don't feel the billet rear servo is needed if using a non low and apply valve body. The servo is only activated in reverse. You can leave the rear pump guts out. an after market front drum is up to you as far as you feel for safety. I personally have run stock Rabestos tan clutchs,drum,low roller,w/5.0 lever and 15 springs in the front clutch in low 10 second 3400lb cars for over 1000 passes w/o an overhaul.
Doug
