Cast pistons or forged in 400HP 360 magnum? #84618
07/05/08 11:22 PM
07/05/08 11:22 PM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
Which pistons would you use in this build? And what brand name?
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: Cast pistons or forged in 400HP 360 magnum? [Re: twister360] #84619
07/06/08 12:51 AM
07/06/08 12:51 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Uhh, only cast pistons out there are going to be stock replacements, and they are probably going to sit a mile in the hole, not what you want from a performance build. If you plan to run nitrous or boost, go forged. If it's just a street/strip motor without boost/nitrous, I would go with a set of hyper pistons.
Re: Cast pistons or forged in 400HP 360 magnum? [Re: DaytonaTurbo] #84620
07/06/08 08:38 AM
07/06/08 08:38 AM
Houma, Louisiana
Houma, Louisiana
I will not run nitrous and there will be no boost. The block is going to be bored 30 over and I plan on using the stock crank and rods, after they are resized. Plan on using a set of EQ heads.
Re: Cast pistons or forged in 400HP 360 magnum? [Re: twister360] #84621
07/06/08 12:54 PM
07/06/08 12:54 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
Even a stock piston for a magnum engine is going to be a hypereutectic cast alloy. But any of the hyper eutectic pistons from Keith Black or Speed Pro will do the trick for a 400HP motor.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Cast pistons or forged in 400HP 360 magnum? [Re: dgc333] #84622
07/06/08 01:06 PM
07/06/08 01:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If I was going to be happy with 400 HP and knew I would never upgrade then the factory magnum pistons would be fine the factory crate motors made 400 with them, however, a set of KB 107s might be cheaper, they would work better and be stronger. 400 hp from the motor you are talking about is a cake walk.
Re: Cast pistons or forged in 400HP 360 magnum? [Re: HotRodDave] #84623
07/06/08 06:15 PM
07/06/08 06:15 PM
Houma, Louisiana
Houma, Louisiana
How would you build this motor? Be brand specific so I can get this on order from Summit. Give all details on how you would make 400 HP. Thanks
Re: Cast pistons or forged in 400HP 360 magnum? [Re: twister360] #84624
07/06/08 06:25 PM
07/06/08 06:25 PM
Manitoba, Canada
Manitoba, Canada
KB107 pistons and aftermarket heads will get you there. Block decked so pistons are zero-deck.
Other than that, research the build on the MP 360ci/380hp crate engines. One of the mopar mags put a good carb on top of one a few years ago, tuned the carb and distributor, did a dyno run and got a little over 400hp out of it.
Re: Cast pistons or forged in 400HP 360 magnum? [Re: twister360] #84625
07/06/08 06:26 PM
07/06/08 06:26 PM
Clinton Twp. Michigan
coronet1966d Offline
Happy Birthday coronet1966d  Offline
theres 100 ways to skin a cat
http://www.geocities.com/alwest_83/dyno
heres a couple
Re: Cast pistons or forged in 400HP 360 magnum? [Re: coronet1966d] #84626
07/06/08 08:32 PM
07/06/08 08:32 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If it was my motor I would use the EQ heads you mentioned. Just spend 5 minutes in each port smoothing down rough spots and transition areas, use the GM 3100V6 springs. Get an eddy airgap intake. Use the KB107 pistons in as small of an overbore as your block will clean up. Zero deck them and use the felpro .039 thick head gasket. I would get the SCAT I beam rods, you would amost spend as much resizeing and buying ARP bolts for yours. The comp 280 magnum cam is mild enough for every day driving and works great with magnum heads. Personaly I would use a Thermo-quad but a 750 holley or eddy of your choice would be ok. Other than that stuff you can get a standard overhaul kit for the gaskets, rings, bearings, and oil pump. Get the best headers that fit your budget.
This combo should be good for about 425hp. If you really think you want to knock off 25 hp don't touch the heads with a grinder and get a comp magnum 270 cam.
Re: Cast pistons or forged in 400HP 360 magnum? [Re: HotRodDave] #84627
07/06/08 09:58 PM
07/06/08 09:58 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if you're starting with a mag motor, instead of using a flat tappet cam like the 280H, I'd look at the comp XR265HR cam, or a custom ground roller cam with 218-226@.050 duration on the intake and the same to +6 degrees on the exhaust, and about .318" lobe lift max...
2017 Grand Cherokee Overland
Re: Cast pistons or forged in 400HP 360 magnum? [Re: patrick] #84628
07/06/08 11:56 PM
07/06/08 11:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I do agree with patrick about the roller cam if you are useing a 89 or newer block, go roller cam and re-use the factory roller lifters and the comp XR265HR cam.
Re: Cast pistons or forged in 400HP 360 magnum? [Re: HotRodDave] #84629
07/07/08 03:30 AM
07/07/08 03:30 AM
Houma, Louisiana
Houma, Louisiana
Yeh I'm either going to get the KB107's or the Speed Pro's from Summit. I'm going to be using a Eddy Air Gap and the Holley 750 3310 carb. Since this is on a budget, I'll probably use the rockers of my cracked magnum heads on the EQ heads. These heads allow a cam with a .550 lift. I don't mind having an aggresive cam, but I'm going to go with a Comp Cam and tell them my application and get a custom grind. As far as headers, again on a budget...I'll probably go with the Flowtech headers in black ($129 brand new).
Anyone know if Summit has a sale or coupon right now or coming up? Because I plan to buy a few things from them and show around e-bag for other parts to save money rather than buying from the machine shop.
Lastly, are the KB107 with a .30 bore on Summit? I've looked and they have three sets of pistons for a 360 maggie with a .30 bore, but the product # is not KB107. They may just have differnt product #'s? If someone knows for could you post a link or the part #? Also would the extra money spent on KB pistons be worth it over the Speed Pros?
Thanks Moparts! Tomorrow the engine will be bored over and the project will be underway!
Re: Cast pistons or forged in 400HP 360 magnum? [Re: twister360] #84630
07/07/08 10:30 AM
07/07/08 10:30 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Summit has them
http://store.summitracing.com/partdetail.asp?part=UEM%2DKB107030%2D8&autoview=sku
In stock too. For $200 you can't get a better piston, speed pros tend to be heavy. You will have trouble not makeing 425 hp with this motor depending on your cam choice really. Are you going flat tappet or roller?
Re: Cast pistons or forged in 400HP 360 magnum? [Re: HotRodDave] #84631
07/08/08 01:14 AM
07/08/08 01:14 AM
Houma, Louisiana
Houma, Louisiana
Dave thanks for the link. I've got a question in regards to those pistons. When I clicked applications it does not say it is for a Magnum motor.
Re: Cast pistons or forged in 400HP 360 magnum? [Re: twister360] #84632
07/08/08 08:21 AM
07/08/08 08:21 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
LA & magnum short blocks are essentially the same.
Re: Cast pistons or forged in 400HP 360 magnum? [Re: twister360] #84633
07/08/08 10:06 AM
07/08/08 10:06 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They will fit a magnum motor with LA rings.
Re: Cast pistons or forged in 400HP 360 magnum? [Re: HotRodDave] #84634
07/08/08 11:14 PM
07/08/08 11:14 PM
Houma, Louisiana
Houma, Louisiana
Spoke with a tech rep with KB and he said you have to use a magnum piston in a magnum motor. The connection rods are different between the 2 motors. He said to use the KB 372030-8 set from Summit. What type and brand of rings should I use?
Re: Cast pistons or forged in 400HP 360 magnum? [Re: twister360] #84635
07/09/08 08:06 AM
07/09/08 08:06 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Isn't the only significant difference between the two the fact that the small end of the Magnum rods are 1" wide and the LA rods wider? Lots of the KB pistons require that the little end of the rod be machined down to 1", or that aftermarket rods be used.
Clair
Re: Cast pistons or forged in 400HP 360 magnum? [Re: twister360] #84636
07/09/08 08:09 AM
07/09/08 08:09 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
bullcrap. the only real difference between the LA and mag rods are the mag rods are narrower on the little end (1" for the magnum, IIRC). you can't fit a piston designed for a magnum rod on an LA rod w/o narrowing the little end, but you can put an piston designed for an LA rod on a magnum rod. heck, most aftermarket rods are narrower than LA rods
on the little end (and pretty much the same as a mag rod), because the same forgings are used for SBC apps.
a KB362, designed for mag rods will give ~1.2 points less compression than a KB107
Re: Cast pistons or forged in 400HP 360 magnum? [Re: patrick] #84637
07/09/08 09:49 AM
07/09/08 09:49 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yeah I call bull pukey!
You talked to a chevy rep at KB. I used a set of the 107s in a 360 mag and it was great.
