Cast pistons or forged in 400HP 360 magnum?
#84618
07/05/08 11:22 PM
07/05/08 11:22 PM
Posts: 406 Houma, Louisiana
twister360
Houma, Louisiana
Which pistons would you use in this build? And what brand name?
My car 74 Duster mild 360/904/3.91 13.44/101.54
Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408
2004 Dodge Ram 1500 Laramie 5.7
2010 Dodge Challenger R/T Classic B-5 6 speed
2010 Jeep SRT8 for the little wife
Re: Cast pistons or forged in 400HP 360 magnum?
[Re: DaytonaTurbo]
#84620
07/06/08 08:38 AM
07/06/08 08:38 AM
twister360
Houma, Louisiana
I will not run nitrous and there will be no boost. The block is going to be bored 30 over and I plan on using the stock crank and rods, after they are resized. Plan on using a set of EQ heads.
[Re: HotRodDave]
#84623
07/06/08 06:15 PM
07/06/08 06:15 PM
twister360
Houma, Louisiana
How would you build this motor? Be brand specific so I can get this on order from Summit. Give all details on how you would make 400 HP. Thanks
[Re: coronet1966d]
#84626
07/06/08 08:32 PM
07/06/08 08:32 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
If it was my motor I would use the EQ heads you mentioned. Just spend 5 minutes in each port smoothing down rough spots and transition areas, use the GM 3100V6 springs. Get an eddy airgap intake. Use the KB107 pistons in as small of an overbore as your block will clean up. Zero deck them and use the felpro .039 thick head gasket. I would get the SCAT I beam rods, you would amost spend as much resizeing and buying ARP bolts for yours. The comp 280 magnum cam is mild enough for every day driving and works great with magnum heads. Personaly I would use a Thermo-quad but a 750 holley or eddy of your choice would be ok. Other than that stuff you can get a standard overhaul kit for the gaskets, rings, bearings, and oil pump. Get the best headers that fit your budget.
This combo should be good for about 425hp. If you really think you want to knock off 25 hp don't touch the heads with a grinder and get a comp magnum 270 cam.
[Re: HotRodDave]
#84627
07/06/08 09:58 PM
07/06/08 09:58 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if you're starting with a mag motor, instead of using a flat tappet cam like the 280H, I'd look at the comp XR265HR cam, or a custom ground roller cam with 218-226@.050 duration on the intake and the same to +6 degrees on the exhaust, and about .318" lobe lift max...
[Re: patrick]
#84628
07/06/08 11:56 PM
07/06/08 11:56 PM
HotRodDave
Kalispell Mt.
I do agree with patrick about the roller cam if you are useing a 89 or newer block, go roller cam and re-use the factory roller lifters and the comp XR265HR cam.
[Re: HotRodDave]
#84629
07/07/08 03:30 AM
07/07/08 03:30 AM
twister360
Houma, Louisiana
Yeh I'm either going to get the KB107's or the Speed Pro's from Summit. I'm going to be using a Eddy Air Gap and the Holley 750 3310 carb. Since this is on a budget, I'll probably use the rockers of my cracked magnum heads on the EQ heads. These heads allow a cam with a .550 lift. I don't mind having an aggresive cam, but I'm going to go with a Comp Cam and tell them my application and get a custom grind. As far as headers, again on a budget...I'll probably go with the Flowtech headers in black ($129 brand new). Anyone know if Summit has a sale or coupon right now or coming up? Because I plan to buy a few things from them and show around e-bag for other parts to save money rather than buying from the machine shop. Lastly, are the KB107 with a .30 bore on Summit? I've looked and they have three sets of pistons for a 360 maggie with a .30 bore, but the product # is not KB107. They may just have differnt product #'s? If someone knows for could you post a link or the part #? Also would the extra money spent on KB pistons be worth it over the Speed Pros? Thanks Moparts! Tomorrow the engine will be bored over and the project will be underway!
[Re: twister360]
#84632
07/08/08 08:21 AM
07/08/08 08:21 AM
patrick
Grand Haven, MI
LA & magnum short blocks are essentially the same.
[Re: twister360]
#84633
07/08/08 10:06 AM
07/08/08 10:06 AM
HotRodDave
Kalispell Mt.
They will fit a magnum motor with LA rings.
[Re: HotRodDave]
#84634
07/08/08 11:14 PM
07/08/08 11:14 PM
twister360
Houma, Louisiana
Spoke with a tech rep with KB and he said you have to use a magnum piston in a magnum motor. The connection rods are different between the 2 motors. He said to use the KB 372030-8 set from Summit. What type and brand of rings should I use?
[Re: twister360]
#84636
07/09/08 08:09 AM
07/09/08 08:09 AM
patrick
Grand Haven, MI
bullcrap. the only real difference between the LA and mag rods are the mag rods are narrower on the little end (1" for the magnum, IIRC). you can't fit a piston designed for a magnum rod on an LA rod w/o narrowing the little end, but you can put an piston designed for an LA rod on a magnum rod. heck, most aftermarket rods are narrower than LA rods on the little end (and pretty much the same as a mag rod), because the same forgings are used for SBC apps.
a KB362, designed for mag rods will give ~1.2 points less compression than a KB107
[Re: patrick]
#84637
07/09/08 09:49 AM
07/09/08 09:49 AM
HotRodDave
Kalispell Mt.
Yeah I call bull pukey!
You talked to a chevy rep at KB. I used a set of the 107s in a 360 mag and it was great.
