Holley fuel pump help please...
#845784
11/04/10 01:59 PM
11/04/10 01:59 PM
Posts: 625 Florida-West Coast
Thor500
Florida-West Coast
The car just doesn't run right, seems like it's running out of fuel, slight hesitation going down the track especially top end. This is just a low compression 440, 750dp, runs 11:50's when it s running right. anyhoo, I just flowed the fuel system ,holley black pump, 3/8 line with an old school Fram filter, both lines out of the regulator in a gas can gets me 1 gallon in a minute, pulled the line before the reg. got 1.5 gallons, right out of the pump gets me a hair over 2 gallons. is this normal? according to the Barry Grant website I need 2 gal. per minute after the regulator for an 11 second car, I'm pullin what little hair I have left OUT! I also flowed it without the element in the filter with no change, and a freshly charged battery.
Re: Holley fuel pump help please...
[Re: Thor500]
#845785
11/04/10 02:18 PM
11/04/10 02:18 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
Try bypassing the fuel filter and reflowed it at the carb Those Fram filters where not designed to be a drag race filter , look closely at how the fuel enters and exits the canister top I know many racers that eneded up using two Fram filters to cure a fuel delivery problem before some of the newer drag race fuel filters where offered
[Re: Cab_Burge]
#845786
11/04/10 02:51 PM
11/04/10 02:51 PM
Challenger 1
Cincinnati, Ohio
