Roller rockers on small block #845002
11/03/10 02:29 AM
11/03/10 02:29 AM
rtplumcrazy1 Offline OP
i am building a 340-will be mostly stock except for cam/headers/carb/intake. I was considering a set of 1.6 roller rockers. The cost is $100 and they are new. I have been told that there is very litle benefit-on a mild 340 like mine. What do you think-worth the money or not
Put a big block 4 speed Scat Pack Dodge in your garage.
Re: Roller rockers on small block [Re: rtplumcrazy1] #845003
11/03/10 07:08 AM
11/03/10 07:08 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Do Not use cheap ones for sure...
Re: Roller rockers on small block [Re: rtplumcrazy1] #845004
11/03/10 08:14 AM
11/03/10 08:14 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Unless you are running a lot of cam with a lot of spring pressure you will be as well off with a set of doctile iron rockers. You will also have to make sure that you have enough spring and also clearance between the valve retainer and guide & seal for any added lift. no matter what rocker you use. Here is an article from our own Dulcich:
From Hughes: The needle bearing rockers are a fairly cost-effective solution but they have reduced life expectancy. All the pressure and shock in the valve train is concentrated on 1 or 2 needles at the most.
The rockers only rock in a small arc of approximately 25 or 30. If the rocker or the shaft actually rotated the needles would live longer. Here again is a conundrum. The smaller needles spread the load over more needles, but they are more fragile you just cant win! Some of the roller rockers even have needle rollers in the roller at the tip of the rocker. The unit loading is very high with needle bearings. All these extra parts are just more points of potential failure.
