Re: R3 block questions
[Re: 80arrow]
#844649
11/02/10 09:01 PM
11/02/10 09:01 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
1 The degree just refers to the lifter bore, correct, the rest of the block is the same?
Yes
2 Are there different heights of the blocks?
Yes, 8.800"-9.600"
3 Are all 48* blocks 340 mains?
Not sure, most all 48 degree blocks will be 340 main but may take a 360 pan depending on the rear cap used.
4 Which of the 48* blocks are best for procharging?
All are great but the R3 with siamesed cylinder bores and 18 head bolts is the strongest. 9.600" deck is prefered to give more room for a dished piston with stroker crank.
[Re: DaKuda]
#844661
11/03/10 11:57 PM
11/03/10 11:57 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
If you are buying one from a private party and not able to lay eyes on it , make sure that it has provisions for wet sump oiling if you intend to go down this road. Some also came with no motor mounts and some had lightening holes in the bell housing area than may prove problematic for tech if you go drag racing with it. Cam bores are for R-3 ony babbit bearings , 50 m.m. roller and 60 m.m. roller. I haven't seen SBF mains , but it doesn't surprise me at all. The book " How to build big inch small block MoPars " goes into a lot of R-3 details. Shady Dell's web site has a lot of info on them and the W heads too. I believe Indy 360's can be had with the extra head bolt bosses too. I like what I am seeing from the Ritter camp. Very nice indeed.
[Re: HEMIDARTS]
#844666
11/04/10 05:19 PM
11/04/10 05:19 PM
Posts: 1,019 Finland
mafo
Finland
do you have any info on weight? ritter vs R3
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
