Anyone build a Magnum 408 stroker and keep it EFI?
#843990
11/02/10 12:11 AM
11/02/10 12:11 AM
Posts: 2,190 SW MO
closer9
SW MO
Thinking about building a 408 stroker Magnum for my '94 (It's a little too much truck for the stock 318), but knowing very little about the ECM and never having built an EFI motor, I'm not sure what my best option is.
Can it be as simple as just bigger injectors? Or am I better off to go with a carb style intake and a stand alone EFI?
Any place I can go to study up on the EFI used, and how it differs from the OBDII that came in '96?
Daily: '19 Frontier 4WD Belle: '67 Belvedere Convertible, 318/727 in Go ManGo! Other: '64 C10, 283/3 on the tree
Re: Anyone build a Magnum 408 stroker and keep it EFI?
[Re: closer9]
#843991
11/02/10 01:03 AM
11/02/10 01:03 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
LOTTA Dakota guys do it...408 strokers, NOS, AND Boost, and they all kept EFI...some even still pass emissions! PM "lastin" he's got a mid 12 second Dakota running a 408 NA with EFI. (that's a 4200 lbs vehicle by the way!!)
**Photobucket sucks**
[Re: closer9]
#843992
11/02/10 01:27 AM
11/02/10 01:27 AM
Posts: 32 Zanesville, Ohio
Last_in
Zanesville, Ohio
The best case would be to convert it to OBD-II or buy a 96' Dakota because they are still a Gen II yet the first year of OBD-II.
With OBD-II you can tune with SCT, which is a easy if staying N/A. Just email tunes with a tuner(usually hemifever) He got my start up tune and first tune pretty close, but after I bought an Lm-2 I could send him logs. Then he could really nail down my A/F ratios and so on. The truck was basically tuned with out ever seeing a dyno.
SCT has really came down in price too, I think I paid $550 for it two years ago. Now it's like $250 with three tunes.
On my truck, I was running the stock fuel system except for Accel 30# injectors.
If you keep the 94' I would say carb or after market EFI or convert to OBD-II. Maybe find a 96, I just sold a 96' RC SB 318 roller that would of been a perfect donor for you about two months ago.
You'll need a bigger throttle body as well. I have ran the Hughes 55mm throttle body and currently running the F&B 58mm throttle body and haven't had trouble with either one.
[Re: Last_in]
#843993
11/02/10 10:08 AM
11/02/10 10:08 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
board member Lt. Dan has one in his ram, but I think his is a '96 and OBD2...
[Re: patrick]
#843994
11/02/10 02:27 PM
11/02/10 02:27 PM
Posts: 2,190 SW MO
closer9
SW MO
Well, did a little more digging around today. Hadn't really heard of Ram guys doing this, but apparently it's not that uncommon. A place called B&G Performance will flash my '94 computer for just such a build. Bigger TB, bigger injectors, bigger fuel pump... Gotta do my homework, but maybe bigger cam and roller rockers.
Not something that will happen right away, especially since the truck runs fine now (just needs more oomph), and the Belvedere interior/top needs finished. Will probably just build this in the corner of the garage as time/money permit.
Still interested in hearing about anyone doing this though. Thanks for the replies...
[Re: closer9]
#843995
11/02/10 08:23 PM
11/02/10 08:23 PM
I built my old 94 Dakota with the a 408 and kept the EFI. I converted the truck to OBD2, used the stock in tank pump, but upgraded the injectors to accel 36 lb/hr and upgraded the throttle body to a hughes stage 2 piece.
[Re: ]
#843996
11/02/10 08:38 PM
11/02/10 08:38 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
Question for the Members who have done stroker Magnums:
If a stock cam was used, would everything still work on the factory PCM without re-flashing? (OBD 2)
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#843997
11/02/10 09:35 PM
11/02/10 09:35 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
the stock cam is so weak and seems to run out of steam...I would not recommend it.
My stroker ran pretty decent on a mopar performance tune, however it runs really good on the sct tune. If you keep the cl of the cam around 114 it should run alright with a stock tune you might throw a misfire codes every once in a while. You might have to go to bigger injectors too, I had to go to 24 lbs over my stock..I know some people say the stock injectors are 24 but I think they are actually 21 lbs.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: blk00rt]
#843998
11/02/10 10:10 PM
11/02/10 10:10 PM
Posts: 3,899 Oregon
hooziewhatsit
What are you guys getting for mileage now, and how heavy are your trucks? (silly question I know, I'm just curious )
[Re: hooziewhatsit]
#843999
11/02/10 10:23 PM
11/02/10 10:23 PM
blk00rt
Michigan Troll
408, 4.56 gears, 4200 lbs truck with a 2400 stall converter ( for now) mileage is about 14-15 highway...maybe a little more.
[Re: ]
#844002
11/29/10 02:10 PM
11/29/10 02:10 PM
Posts: 892 Illinois
StrkrDart69
Illinois
Off topic..b5sixpackbee where did you get those valve covers?
