Narrowing an 8 3/4 #843391
11/01/10 09:23 AM
11/01/10 09:23 AM
Champion City
The Sphinx Offline OP
Champion City
Anyone know of a place in in the northern Ohio/ southern Michigan that can narrow a mopar 8 3/4?
Re: Narrowing an 8 3/4 [Re: The Sphinx] #843392
11/01/10 10:21 AM
11/01/10 10:21 AM
ohio
all spooled up Offline
ohio
Re: Narrowing an 8 3/4 [Re: all spooled up] #843393
11/01/10 10:53 AM
11/01/10 10:53 AM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
Dick, What are you looking for dimesion wise??? I have a narrowed housing for sale cheap. Its set up for ladder bars and coil overs. Easy to weld a set of pad on if you are going the leaf spring way. Its already back braces, upper filler cap and a bottom drain. There are braces from the coil over mounts as well for added rigidity. If you are interested I can get exact widths and such. Thanks, Ken
Re: Narrowing an 8 3/4 [Re: The Sphinx] #843394
11/01/10 11:45 AM
11/01/10 11:45 AM
Champion City
Champion City
I wish to have an e-body rear cut down to a-body specs
