I have a 1970 440 engine bored .030 over with a Lunati 60302 cam. Lunati Voodoo 60302 262/268 adv duration .475/.494 lift 220/226
duration@.05 112 deg lobe separation.
Holley 750 dual line vaccum secondary carb. HP manifolds. 906 Heads thats had a 3 angle valve job. Electronic ignition. What kind of horse power you guess it might be putting out? It was originally a non HP 440 engine out of a CHRYSLER NEW YORKER. I was told back then it would have been 350 HP rating. With what Ive done to it. Is it in 400-425 hp range now?
![](/ubbthreads/images/graemlins/shruggy.gif)
