NORMAL COMPRESSION??? #841571
10/29/10 05:31 PM
10/29/10 05:31 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Is there a "NORMAL" range when checking compression with a gauge? My 440 has a 10:25 ratio,using stock 84cc Edelbrocks. The cam is a solid with .600 lift and 262/266 @ .050 duration. Thanks in advance! RandyB
Re: NORMAL COMPRESSION??? [Re: Labratt] #841572
10/29/10 05:51 PM
10/29/10 05:51 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
There might be, but hard to say when you have large overlap cams bleeding compression out the exh valve.
When you test, make sure you run the test the same way. Like warm the engine up, and test with the carb at WOT. Make sure the battery doesnt run down so you have the same cranking power. This can effect the numbers, or if the engine cools etc.
Look at each cylinder and they should be with in 5% of all others.
I like my race engine in the 225-250 lbs + range.
I healthy street engine should approach 200 psi. But many factors come in play here
Re: NORMAL COMPRESSION??? [Re: Labratt] #841573
10/29/10 05:56 PM
10/29/10 05:56 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
You'll probably fall in the area of 160-170 psi. You need to crack the throttle at least 1/4 open and crank away until the guage stops moving.
Re: NORMAL COMPRESSION??? [Re: Bob_Coomer] #841574
10/29/10 07:03 PM
10/29/10 07:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mr. Coomer, are you serious 225-250+ cranking compression? I know lots of 8-sec. and faster cars and NONE that I have talked to crank in that range. Some are in the low 130-140 range. You racing a diesel?
Re: NORMAL COMPRESSION??? [Re: Thumperdart] #841575
10/29/10 07:18 PM
10/29/10 07:18 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Nope
most any car out of the factory is 175-180 psi. Why would you think a race engine should be lower? I know some is lost due to cam profiles, but thats why they make dome pistons and closed chamber heads for
I dont see how you can keep from it. Unless its a pump gas engine. I dont care how big the cam is either. Last wedge was at 16:1 and ran real, real good. But again I dont build pump gas engines.
Last one was a 493 with Eddy heads, and the 590 MP solid...heck it had 180-190 IIRC
If you build a engine with 13-14:1 compression expect it..
IDK what to say about the guys running 130 psi. I bet they would benefit in more compression or less cam
I be willing to lay money on it that Randys will approach 200 psi....
175+ anyways
Re: NORMAL COMPRESSION??? [Re: Bob_Coomer] #841576
10/29/10 07:24 PM
10/29/10 07:24 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my 14-1 small block stroker with a solid roller with 267/272 @ 50 only has 190# and the leakdown is less than 3% and it runs 6.32 at 109 in the 1/8 in a car that is 2975 lbs.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: NORMAL COMPRESSION??? [Re: Bob_Coomer] #841577
10/29/10 07:25 PM
10/29/10 07:25 PM
ohio
all spooled up Offline
ohio
my small block 230-235 psi cam is solid roller 650 lift duration at .020 in 296 exh 303
@ .050 263 270 in at 106
Re: NORMAL COMPRESSION??? [Re: all spooled up] #841578
10/29/10 08:35 PM
10/29/10 08:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Guess our junk`s wore out.
Re: NORMAL COMPRESSION??? [Re: all spooled up] #841579
10/29/10 08:58 PM
10/29/10 08:58 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Whats the compression ratio?
Re: NORMAL COMPRESSION??? [Re: emarine01] #841580
10/29/10 09:02 PM
10/29/10 09:02 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Based on the PSI though, I will guess, 13.5 or more
Re: NORMAL COMPRESSION??? [Re: Thumperdart] #841581
10/29/10 09:25 PM
10/29/10 09:25 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
No,
Just points to how inaccurate a compression test is at telling you anything.
About the only thing you can learn from one is if you took one and wrote it down when the engine was built and then compared it to when you think you may have a problem.
I prefer a leak down test myself.
Re: NORMAL COMPRESSION??? [Re: Labratt] #841582
10/29/10 09:51 PM
10/29/10 09:51 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
look for it to be 160 to 165 cranking compression
Re: NORMAL COMPRESSION??? [Re: Dodgem] #841583
10/29/10 09:52 PM
10/29/10 09:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
or plug your numbers into this
http://www.rbracing-rsr.com/comprAdvHD.htm
Re: NORMAL COMPRESSION??? [Re: Dodgem] #841584
10/30/10 01:16 AM
10/30/10 01:16 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I just checked a couple of cylinders for S&G's! One was 175psi..the other was 173 or so! Didn't know about holding the carb open,though! Thanks fella's! RandyB
Re: NORMAL COMPRESSION??? [Re: Labratt] #841585
10/30/10 01:37 AM
10/30/10 01:37 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thats more like it. On one of your other threads you registered 185 PSI witch I felt was high for your combo. IMO with around 10.25 Comp and that 262* cam your 170-175 PSI is in the normal range for the combo. Maybe even a little high.
But, FWIW, the Calulater that Dodgem posted was Happy about by 20# PSI for my Combo. But with your engine specs, it was almost right on. mike
Re: NORMAL COMPRESSION??? [Re: Bob_Coomer] #841586
10/30/10 10:44 AM
10/30/10 10:44 AM
New York
polyspheric Offline
polyspheric  Offline
New York
How exactly does this happen?
Boffin Emeritus
Re: NORMAL COMPRESSION??? [Re: polyspheric] #841587
10/30/10 10:56 AM
10/30/10 10:56 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
...out the exhaust valve" ???????
Re: NORMAL COMPRESSION??? [Re: Labratt] #841588
10/30/10 11:07 AM
10/30/10 11:07 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If your doing it for S&G, and you like data, pick a cylinder, get a good consistant technique and baseline numbers, then change your intake lash plus 0.004" and minus 0.004". And then of course report back
Re: NORMAL COMPRESSION??? [Re: BSB67] #841589
10/30/10 12:24 PM
10/30/10 12:24 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Russ..I might just try that in the near-future! If I do,I'll be sure to post the results! BTW...how important is it to have the butterflies partially open,as Hardcore suggests?
Re: NORMAL COMPRESSION??? [Re: BSB67] #841590
10/30/10 12:24 PM
10/30/10 12:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Which cam is that where the exhaust valve is open during the compression stroke?
Boffin Emeritus
