There are 2 W2 patterns, but I've run W2 headers on X heads before. Adapters are not a big deal, just be sure to have them ground dead flat, and you can use the high-temp orange silicone to seal everything. It'll be easier to mount everything up if you cut the flanges, which I do on every set of headers anyway, for that reason as well as to eliminate warpage, lose a couple of pounds, improve spark plug access, and improve appearance.
Double-check the flanges if you want to run 13/16" plugs, some are tight; 5/8" is no problem.
