1970 RR 4speed neutral safty switch #840985
10/28/10 03:02 PM
10/28/10 03:02 PM
michigan
jordan91 Offline OP
jordan91  Offline OP
michigan
How do you wire up a neutral safety switch. Or should i even bother with it.
Re: 1970 RR 4speed neutral safty switch [Re: jordan91] #840986
10/28/10 04:49 PM
10/28/10 04:49 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
There's a switch on the clutch pedal that grounds the starter relay when the clutch pedal is depressed. I disconnected it because I don't like the idea of all that pressure on the crank thrust bearing when starting a cold engine. I don't think there's an easy way to wire up a neutral safety switch.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: 1970 RR 4speed neutral safty switch [Re: Mick70RR] #840987
10/28/10 06:25 PM
10/28/10 06:25 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
On my 70 RR I uninstalled the clutch switch, grounded the starter relay and put the switch on E-bay..
They are selling for $150 if in good condition..
Just my $0.02...
Re: 1970 RR 4speed neutral safty switch [Re: Sinitro] #840988
10/28/10 07:33 PM
10/28/10 07:33 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I left mine where it belonged,it's still there after 18yrs!
