E85 fuel pumps #837731
10/24/10 06:34 PM
10/24/10 06:34 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
Hoping someone can help
Are the Aeromotive fuel pumps compatible with E85?
Has anyone run a #11102 pro-series Aeromotive pump on here.... feedback?
Darren Beale
Keith Black Racing Engines®
Re: E85 fuel pumps [Re: Keith Black®] #837732
10/24/10 07:06 PM
10/24/10 07:06 PM
QLD Australia
QLD Australia
anyone..?
Darren Beale
Re: E85 fuel pumps [Re: Keith Black®] #837733
10/24/10 07:13 PM
10/24/10 07:13 PM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
I believe any gas pump is compatible with e85.
Re: E85 fuel pumps [Re: 68valiant68] #837734
10/24/10 07:19 PM
10/24/10 07:19 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Running one right now.
Re: E85 fuel pumps [Re: Twin Turbo Mower] #837735
10/24/10 07:54 PM
10/24/10 07:54 PM
QLD Australia
QLD Australia
thanks Dan,
it runs with E85.
are you running it in-tank? quiet..?.. noisy..?..
do you know if it's the same size as the A1000 ?
what filters are you running (stainless?)..
Darren Beale
Re: E85 fuel pumps [Re: Keith Black®] #837736
10/24/10 08:55 PM
10/24/10 08:55 PM
Mt.Vernon IL
Mt.Vernon IL
I have it on the outside. I have the eliminator pump a step up from the a-1000 http://aeromotiveinc.com/products-page/fuel-pumps/11104-eliminator-fuel-pump/
I also run the pump controller they sell. http://aeromotiveinc.com/products-page/a...eed-controller/
It really helps quiets the pump down at idle, but my car is pretty thumpy sounding to even try to hear the pump.
I run russell brand filters.
Re: E85 fuel pumps [Re: Twin Turbo Mower] #837737
10/24/10 10:23 PM
10/24/10 10:23 PM
QLD Australia
QLD Australia
thanks Dan,
was the #11104 pump housing physically larger than the A1000?
& are you running E85? apparently not all pumps are compatible
Darren Beale
Re: E85 fuel pumps [Re: Keith Black®] #837738
10/24/10 10:31 PM
10/24/10 10:31 PM
Mt.Vernon IL
Mt.Vernon IL
Yes I am running e-85 right now. I just have not ran it at the track yet. The pump looks the same size. I went from the a-1000 to the #11104 when I decided to run e-85 just incase the 1000 was not enough. I also went with bigger injectors ect.
Re: E85 fuel pumps [Re: Twin Turbo Mower] #837739
10/25/10 02:12 AM
10/25/10 02:12 AM
QLD Australia
QLD Australia
awesome, thanks. I think I'll go with the #11102 just to be safe. I think it'll be the same size physically.
will check out the filters you suggested as Aeromotive don't seem to list stainless outlet filter elements with -12 sizing.
thanks again Dan.
Darren Beale
Re: E85 fuel pumps [Re: Keith Black®] #837740
10/25/10 02:27 AM
10/25/10 02:27 AM
Mt.Vernon IL
Mt.Vernon IL
This is what I have before the pump
http://www.summitracing.com/parts/EAR-230212ERL/
This is the smallest micron filter I could see for a -12 line setup after the pump
http://www.summitracing.com/parts/PFS-10302/
you just need 1/2 npt fittings to -12
I have a -12 pickup but only -10 line from the pump to the front of the car.
Re: E85 fuel pumps [Re: 68valiant68] #837741
10/25/10 08:50 AM
10/25/10 08:50 AM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
any gas fuel pump will "work" with e85, but it will fail pretty quickly.
The internal parts of an E85 pump are made of different materials than a gasoline pump, which are able withstand the corrosive nature of e85.
Re: E85 fuel pumps [Re: chache876] #837742
10/25/10 05:04 PM
10/25/10 05:04 PM
QLD Australia
QLD Australia
Yes that is also my understanding, also that you need stainless steel filters (as paper will fail). I still do not have a definitive answer on the Aeromotive pumps for continuous duty with E85 (#11101 (A1000) through #11104).. any comments and/or experience appreciated !!
Darren Beale
Re: E85 fuel pumps [Re: Keith Black®] #837743
10/25/10 06:14 PM
10/25/10 06:14 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
magnafuel and holley pumps are good , not BG pumps and regulaters
no problems with paper filters such as FRAM
running all year and still no problem
fuel cell foam and aluminum cell ok
viton n&s no good
WAXER
Re: E85 fuel pumps [Re: QWK_ENUF] #837744
05/31/12 10:14 PM
05/31/12 10:14 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Instead of starting a new post i did a search and came up with this I have a ? concerning the regulators with e-85 i also run the a-1000 pump &regulater did anyone have to adjust the presure with the switch to e-85?....
Re: E85 fuel pumps [Re: QWK_ENUF] #837745
05/31/12 10:41 PM
05/31/12 10:41 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
viton n&s no good
I called and asked before I bought my 220HR from B.G. and was assured it was E-85 compatible.
I hope they weren't lying.
Re: E85 fuel pumps [Re: tubtar] #837746
05/31/12 11:53 PM
05/31/12 11:53 PM
PA
ajcasini Offline
ajcasini  Offline
PA
I haven't had ant problems with their pumps. 4 years on a bg400 with no issues. I would not run the regs as the ethanol eats the seats in them. Saw this first hand last year on the 2ports. I ran a 4 port for 2 years with no problems but after seeing what happened with the 2port I will not run it anymore.
Re: E85 fuel pumps [Re: ajcasini] #837747
06/01/12 08:33 AM
06/01/12 08:33 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
AJ, what are you running as a regulator on your car? I've heard about the diaphragm regulators being ate up also from E85
Re: E85 fuel pumps [Re: 340_Dart] #837748
06/01/12 08:41 AM
06/01/12 08:41 AM
PA
ajcasini Offline
ajcasini  Offline
PA
Right now a quick fuel dead head. It one of the holley look a like. Cost about 20 bucks.
Re: E85 fuel pumps [Re: ajcasini] #837749
06/01/12 08:43 AM
06/01/12 08:43 AM
tboomer Offline
tboomer  Offline
AJ...What do you use for fuel line?
Re: E85 fuel pumps [Re: tboomer] #837750
06/01/12 04:00 PM
06/01/12 04:00 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
I will only comment on pumps that I have personally used with E85.
Have had no issues with BG280, Holley black and ProComp black.
But the motors on the ProComp pumps don't last long.
