Re: Vapor Lock
[Re: convx4]
#837000
10/25/10 12:11 AM
10/25/10 12:11 AM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
at this point, i have really ruled out Vapor lock, i have not had the car running long enough and hot enough for Vapor Lock, i apprently have a fuel problem, tank, fuel pump, fuel pump rod or ???, hopefully when i do the test tommorrow i can determine if the pump is pumping a steay stream. thanks
Re: Vapor Lock
[Re: cornet684me]
#837002
10/25/10 12:21 AM
10/25/10 12:21 AM
RapidRobert
1st do Joe's test w 2 jugs. W the carb bowl full (fill it 1st w a turkey baster) you'll have 5-10 seconds b 4 the bowl runs dry & that'll be enough time to see if the pump is pulsating a good stream & if not then yes take out the plug & the rod
Re: Vapor Lock
[Re: cornet684me]
#837007
10/25/10 12:52 AM
10/25/10 12:52 AM
RapidRobert
But do wait until she stops the evil eye. W women it's all in the timing. Good luck w it (the car) & holler back when you find something, I gotta hit the hay.
Re: Vapor Lock
[Re: RapidRobert]
#837008
10/25/10 01:46 AM
10/25/10 01:46 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Got that right , they can & WILL be nasty when pravoked !!!!
Re: Vapor Lock
[Re: cornet684me]
#837009
10/25/10 07:50 AM
10/25/10 07:50 AM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
so i need to take the rod out and just measure the rod?
Yes, pull the pump out and take out the plug underneath it. The rod should come down if it is not mushroomed on the cam end. Good luck.
Re: Vapor Lock
[Re: joedust451]
#837010
10/25/10 10:23 PM
10/25/10 10:23 PM
cornet684me
Brandon, Ms
okay guys, i think i have narrowed it down to the fuel line from the tank and the sending unit, i really did not think i needed to replace since it was a daily driver for so long, i guess i am going to go ahead and replace the tank, sending unit and the fuel line? i have attached a pic. of the fuel filter while running from a hose put in a gas can, i let it run till normal temp of engine and it never fell before half full, is this where the fuel is suppose to be on this type of fuel filter?
Re: Vapor Lock
[Re: ireland383]
#837011
10/25/10 10:27 PM
10/25/10 10:27 PM
cornet684me
Brandon, Ms
i checked the rod when i put the new pump on, it did look mushroomed, however i did not take it out and measure it
Re: Vapor Lock
[Re: cornet684me]
#837014
10/26/10 08:28 AM
10/26/10 08:28 AM
Challenger 1
Cincinnati, Ohio
I'd be taking it out and measuring it before I did anything else.
Re: Vapor Lock
[Re: cornet684me]
#837015
10/26/10 10:35 PM
10/26/10 10:35 PM
cornet684me
Brandon, Ms
update- dropped the tank, the tank is as clean as a new one, the sending you perfect shape, i am going to blow out the hard line, i guess i need to pull the fuel pump rod, i tested the pump and it tested fine, i have checked out everything and do not know why the fuel filter goes empty when the car is running?
Re: Vapor Lock
[Re: cornet684me]
#837016
10/26/10 11:35 PM
10/26/10 11:35 PM
RapidRobert
I did not think i needed to replace since it was a daily driver for so long, i guess i am going to go ahead and replace the tank, sending unit and the fuel line? i have attached a pic. of the fuel filter while running from a hose put in a gas can, i let it run till normal temp of engine and it never fell before half full, is this where the fuel is suppose to be on this type of fuel filter?
Randy I read this thru several times to try & get a handle on the prob & possibly contribute. Yes if it never fell below half full then the pump/rod is Ok & the prob is rearward from the pump as long as it isn't escessive heat that is boiling it & we're thinking no on that but b 4 you drop the tank/sender I'd continue on w the same test you just did (a jar of gas connected to the pump inlet) & let it run until it is real good & hot (assuming you havent already) & see if it vapor locks/dies idling in your driveway & you can keep tabs on the filter. If it stays good & by now you've visually checked the hard line/2 neoprene connector pieces) I would take the jar and your hose and plumb it to the rear of the hard line there as it enters the sender & repeat. That only leaves the sender as you dont want to have to mess w it or the tank if you dont have to. I know you said the tank/sender looked OK but the sender may have a crack but one thing at a time & the jar hooked up to the rear line will tell you something. EDIT & you're not running E10 (gasahol) right?
