69 Roadrunner Vent Window #836576
10/22/10 11:28 PM
10/22/10 11:28 PM
in
P
pgccp Offline OP
pgccp  Offline OP
P
in
Can someone tell me if part # 2811340 vent window
right side will fit a 69 roadrunner guy says they came off a 68 charger should fit my roadrunner
Thanks Bob
Re: 69 Roadrunner Vent Window [Re: pgccp] #836577
10/23/10 12:42 PM
10/23/10 12:42 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Are you sure that number is correct? And you're talking about the glass, not the frame, right? I'm not finding a 2811340 at all. My book says the vent windows are as follows:
2811358 & 9 Clear
2811360 & 1 Tinted
These are the same for '68-'70 Dodge & Plymouth B-body 2 door Sedans and Hardtops. Hope that helps.
Re: 69 Roadrunner Vent Window [Re: pgccp] #836578
10/24/10 12:44 AM
10/24/10 12:44 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Vent windows , frames and glass, interchange between Dodge and Plymouth models..
However, 4 door and converts are different...
