Re: Easiest way to remove hydraulic lifters??
[Re: copper67440]
#836002
10/22/10 01:56 AM
10/22/10 01:56 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
If you engine is reasonably clean, a magnet on an extension works well... Stubborn ones may require some carb cleaner to get the varnish off. Otherwise, pull the intake and rocker arms and grab em...Big blocks are nice with no water in the intake.. just a $25 gasket... Just to add note that back in the day Solder Seal use to make a product called lifter quiet that did a great job of cleaning the lifters in a few hudred miles, eliminating the need to replace them.
[Re: StealthWedge67]
#836005
10/22/10 04:22 AM
10/22/10 04:22 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Pull the valve covers and rocker assembly, remove the pushrods and pull the lifters out with a lifter extracting tool. No need to remove the intake.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#836013
10/22/10 12:02 PM
10/22/10 12:02 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I've done it with a coat hanger...now getting the new one in is a trick.
#836015
10/22/10 03:21 PM
10/22/10 03:21 PM
Posts: 3,958 SW Fla.
CYACOP
SW Fla.
Guys, on a big block, pulling the intake is a 10 minute job. It then gives the benefit of actually seeing what you are working on. To me, its a no-brainer.
It takes longer to pull AND reinstall the intake by the time you get done with the wiring, throttle linkage, gasket cleaning and pan cleaning. He just wants to swap out some lifters. What I didnt say last time was the fact that sometimes the lifter will not pass through directly above that lifter due to rough castings but I have always just passed it to the known wide enough passage and put them in the same way. Its a "no-brainer".
[Re: CYACOP]
#836016
10/22/10 09:22 PM
10/22/10 09:22 PM
Posts: 644 Warner Robins, Georgia
DusterMan
super street
super street
I had a pair of mechanical fingers that I cut the end off so when you extended them they would go under the snap ring or catch real good in the lifter. Pull them right out and install.
Pete: 2003 Dodge Quad 2500 Hemi 69 RoadRunner 4 sp Alpine White 2019 Dodge Charger
[Re: CYACOP]
#836017
10/22/10 09:31 PM
10/22/10 09:31 PM
Posts: 21,839 Kirkland, Washington
Pacnorthcuda
Through the valve cover is very sanitary. Why break an intake seal when you don't have to? Done is several times, very fast, very easy. And rare earth magnets ROCK!!!!
[Re: Pacnorthcuda]
#836018
10/23/10 12:09 AM
10/23/10 12:09 AM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
If you have a stubborn lifter or 12, a lifter removal tool is always helpful. I don't know what you have in your area, but any well stocked parts supply house should have them in their specialty tool section. Relatively inexpensive as well. I think I paid $12-$18 for mine a few years ago.
It's a long tool with a spring loaded T handle on one end and retracting claws on the other. Basically, you hook the claws into the top of the lifter and pull up on the T handle. Upwards pressure on the T handle pushes the claws out further into the lifter to aid bite.
This tool is a necessity when working on ANY AMC. I'm up to 5 AMC's, and even the low-miler needs lifters. Its got two dead ones for sure!
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
