Page 3 of 3 1 2 3
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: B G Racing] #835547
10/26/10 07:35 AM
10/26/10 07:35 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
The prob is u use 2 tubes of silicone and have more chance of leaking with a wider gap,you will still have pressure inside the block that will create blow-by as soon as the oil gets hot and starts sloshing around it will find a way out if there is any error in the silicon gasket.the attached pic is the way i do a indy vally tray,i cut the center out of the indy tray bevel both sides and take a new peice of alum and machine opp bevels, slot the holes in the outboard plates so the more u tighten the center plate the more it pushes twards the head,
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: Labratt] #835548
10/26/10 09:56 AM
10/26/10 09:56 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
RatTrap,care to wager on your oil leaking assumption??? The gap was miniscule,contrary to what some of you were thinking! But,everyone's entitled to their opinion! So...how much on our wager??? Remember though, I am on a budget! Respectfully, RandyB
Randy, I'll back your wager! You'll be fine.
Randy
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: Dartin] #835549
10/26/10 11:13 AM
10/26/10 11:13 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Randy! The wager must not be on! My concern is if the doubled-up Moroso vc gasket hangs in there and does the job on the oil leak! Oil and headers doesn't make a good combination! Planning on doing some carb testing in a short while. Right now I've got the "borrowed" Bigs 950HP bolted up!
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: Labratt] #835550
10/26/10 11:49 AM
10/26/10 11:49 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I think ur doubled valve cover gaskets will leak also, Whats the issue that u need 2 double the gasket??
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: RATTRAP] #835551
10/26/10 12:15 PM
10/26/10 12:15 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
RT,no wager on the vc gaskets not leaking! Another experiment! I wanted to extend the distance the oil has to travel to seep out between the vc and gasket,that's all! So far,after running engine for 15-20 minutes,looks dry where it was dripping with the new,thin gasket that I just got! That could change,I'm sure!
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: Labratt] #835552
10/26/10 12:42 PM
10/26/10 12:42 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I hope ur project seals good as oil leaks are a pain, I roll under the rule,If u think it will fail it prob will,so do it right before it happens. Keep us updated after a good road test.
This is the best rtv that i have found
RTV
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: Labratt] #835553
10/26/10 02:04 PM
10/26/10 02:04 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Bill,unfortunately,the vc gasket that leaked was one of Greg's! I just snugged it..not over-tightened whatsoever!!! Maybe he has some advice!???
RandyB, hear there is a valve cover leak issue with one side.
Is the other side ok and not leaking?
Check your valve cover for flatness in the area of the leak.
Don't be afraid to tighten the bolts, it's not cork and won't squish out as easy.
if you need help! 1-866-925-7855
Greg
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: roadhazard] #835554
10/26/10 03:58 PM
10/26/10 03:58 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I like the cork gaskets designed to swell and fill the void. If the gasket is sliding when ur snugging the bolts u have all ready failed
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: ProSport] #835555
10/26/10 04:51 PM
10/26/10 04:51 PM
GA
Boosted Offline
Boosted  Offline
GA
I thought about one of those for my motor.. I took a regular pan for stage 6 heads and made mine... Has a lexan middle to see the push rods easy..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: Boosted] #835556
10/26/10 05:20 PM
10/26/10 05:20 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
ANY PICS
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: Boosted] #835557
10/26/10 05:43 PM
10/26/10 05:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Good luck with that ... lexan has a lower melting point than your engine's operating temp. I've seen S/S hemi cars with small windows on the valve covers which are fine due to the small area and where they are but putting a window in the valley is asking for trouble. There's a reason you don't see anyone else doing this and it isn't because you're the first to have the lightbulb go on!
Re: INDY VALLEY PLATE RETROFITMENT COMPLETED! [Re: RATTRAP] #835558
10/26/10 06:15 PM
10/26/10 06:15 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Page 3 of 3 1 2 3
