Pre-milled heads? #833484
10/19/10 02:17 AM
10/19/10 02:17 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Seems I remember a way to tell if big block heads have already been milled (aside from any pattern visable on the head surface). Isn't there an area on the head perimeter somewhere that is supposed to be exactly 1" thick if the heads are virgin?
Re: Pre-milled heads? [Re: polkat] #833485
10/19/10 10:22 AM
10/19/10 10:22 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Measure at lower corner head bolt areas, I've measured many over the years and found virgin uncut heads can be anywhere from .990 to 1.015. You should also cc the head if your doing compression up grades to equalize chambers, etc.
logan426
Re: Pre-milled heads? [Re: polkat] #833486
10/19/10 12:04 PM
10/19/10 12:04 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yup right around an inch bang on!
