A833 4 speed tail shaft #832902
10/18/10 03:24 PM
10/18/10 03:24 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I have a 1973 cuda with the original front case on a A833 transmission c99129H built on 4115 Nov 2 1972. It did not come with a tail shaft. What is the part number for the proper tailshaft?
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: A833 4 speed tail shaft [Re: 19cuda73] #832903
10/18/10 04:17 PM
10/18/10 04:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is it a big block trans or a smallblock trans ? The casting number on the case is the same whether it's a big or smallblock trans, the tail housing is different depending on the bearing size but hole in the case is the same either way.
As far as what one you need it's the one with 2 shifter mounting pads, that's the only one for use in an E body.
Re: A833 4 speed tail shaft [Re: JohnRR] #832904
10/18/10 04:52 PM
10/18/10 04:52 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
C99539 is the tailshaft casting number for the 70 & newer B/E body cars.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: A833 4 speed tail shaft [Re: 64dodge572] #832905
10/18/10 04:59 PM
10/18/10 04:59 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
There is a nice used one on E-bay right now.
Re: A833 4 speed tail shaft [Re: 64dodge572] #832906
10/19/10 03:08 PM
10/19/10 03:08 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks Dan what is the correct brewers rebuild kit for this unit??
1972 Corvette
Re: A833 4 speed tail shaft [Re: 19cuda73] #832907
10/20/10 09:10 AM
10/20/10 09:10 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
This would be the one, as long as the front bearing retainer is casting #c94796:
http://brewersperformance.com/proddetail.asp?prod=RBK05
Dan
FAX 937-947-4419
