Steering wheel not straight after changing K-frame???
#832865
10/18/10 02:26 PM
10/18/10 02:26 PM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
I changed the K-frame on my '70 Challenger and now the steering wheel isn't straight. I had to remove the bolts from the steering box to swap out the frame (supported by rope and 2 X 4s) but I never touched the column. What would cause the steering wheel to be at a 90 degree turn now? I know I need to go get everything aligned with having a new K-frame but it was perfectly straight before I did the swap. It's very strange... Thanks! Steve
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
Re: Steering wheel not straight after changing K-frame???
[Re: burdar]
#832867
10/18/10 02:50 PM
10/18/10 02:50 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
if the steering box is 5 turns lock to lock...make sure it is in the middle...there is a key way that the column slides on to...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: burdar]
#832868
10/18/10 04:22 PM
10/18/10 04:22 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
The box is in a slightly different location than it was with the old k member in place. Moving the box will change the alignment. Change the alignment and the wheel moves off center.
[Re: Plum440]
#832869
10/18/10 05:14 PM
10/18/10 05:14 PM
Posts: 2,836 Detroit boy in Saugerties, NY
BrianShaughnessy
The dead spline on the steering box, the coupler and the steering shaft all go straight up 12 o clock.
Center the box at 2.5 turns and check where the dead spline is. If it's off a half turn, pull the coupler out and get them all lined up.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana. Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart. El Grande: '98 Grand Cherokee 5.9 Limited.
[Re: Plum440]
#832870
10/19/10 12:39 AM
10/19/10 12:39 AM
JohnRR
U.S.S.A.
Thanks!
Steve
Sounds like he never disconnected the steering column from the steering box to me .
[Re: Kern Dog]
#832872
10/19/10 02:17 PM
10/19/10 02:17 PM
Plum440
Slidell, LA
The K-frame I have actually came from a B-Body. I'll just wait until everything is done and have it adjusted when aligned. Thanks!
[Re: Plum440]
#832873
10/19/10 03:38 PM
10/19/10 03:38 PM
JohnRR
U.S.S.A.
Thanks!
What year B body , 70 down has a different steering box mounting angle than 71-72.
[Re: JohnRR]
#832874
10/19/10 06:16 PM
10/19/10 06:16 PM
Plum440
Slidell, LA
Haven't a clue. The guy I bought it from thinks it's a '68 or '69. No numbers on it to check.
[Re: Plum440]
#832876
10/20/10 08:26 AM
10/20/10 08:26 AM
JohnRR
U.S.S.A.
If that is the case then it's no wonder your steering wheel is off since that K frame is not the same as the one you needed for your car, you need to have it aligned again. Have you tried mounting your swaybar yet ?
[Re: ahy]
#832877
10/20/10 08:28 AM
10/20/10 08:28 AM
JohnRR
U.S.S.A.
It may be as simple as adjusting the tie rod sleeves to re-align with the slightly different box location.
That's a given anytime you do something MAJOR to the front suspension, the OP obviously thought he could put the WRONG K frame in the car and be good to go ...
OP are you related to member polkat ??? ... kidding ...
[Re: roadrunninMark]
#832879
10/22/10 05:05 PM
10/22/10 05:05 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
What K was in the car. Could a /6 k have a different box mounting position than a V8 one?
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
#832881
10/22/10 06:13 PM
10/22/10 06:13 PM
JohnRR
U.S.S.A.
mine is the original k, i can center it with a few turns of the tie rod sleeves, just thought it would be nice to have it centered the way it should be right from the get go.
What steering box do you have , correct small sector of later large sector ?
#832883
10/22/10 07:13 PM
10/22/10 07:13 PM
JohnRR
U.S.S.A.
I have the aluminum cased manual box, whichever was the factory box for a 69 B-body. What is small sector vs. large sector and how would I determine that?
Small sector is 72 down , large is 73 up , is it your original box ?
#832884
10/22/10 07:22 PM
10/22/10 07:22 PM
Posts: 7,664 IN
ahy
IN
Funny, I just came across this issue as well. I just put the new front suspension in and equaled the tie rod sleeves so everything is same one side to the other. I just put the column in and my dead spline was off as well. So in my case, besides taking the column out, I need to take off the pitman arm and let the manual box spin until the dead spline is at the 12 oclock position then the column shall line up correctly?
Usually there is a master spline on the pitman, steering coupler and steering wheel. It is not possible to adjust clocking... with one exception! If the steering pot coupler is assembled 180 degrees out of phase it will throw the clocking off so much that tie rod adjustment won't fix it. I sent a column out for rebuild; after re-install I couldn't get the wheel centered with maximum tie rod adjustment. I disassembled the pot coupler and re-assembled 180 degrees opposite and all was well. This was from a tip in a MA tech article.
