Re: Thermoquad on RPM Air Gap
[Re: ademon]
#832199
10/17/10 07:27 PM
10/17/10 07:27 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
i looked at my ld340 and there isn't much room there also, it looks like if you open it to the good gasket or plastic spacer there would only be about .030 on the secondary side unless you weld. NE1 have a pic of a LD340 opened up to T-quad size.
I don't have a picture, but I hogged my LD340 out a few years back and there is plenty of room left after doing it and I'm using the big bore TQ with no issues at all.
[Re: MoparforLife]
#832200
10/17/10 07:28 PM
10/17/10 07:28 PM
JonC
Millinocket, Maine
You would have the same problem with and LD340. They are not set up for a thermoquad either. yes it will work with a little grinding but why not just get an adapter.
On a non shaker Ebody, there isn't a lot of room under the hood for a LD340, TQ and adapter plate.
[Re: CokeBottleKid]
#832204
10/17/10 10:02 PM
10/17/10 10:02 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
I foolishly had that same combination for a litte (Thermobog on an RPM air gap). Just use an adapter... or better yet use a real carb.
A properly tweaked THERMOquad does NOT have a BOG issue at all ...PEPSIkid
And an ADAPTER is fine on a truck or RV ... but anything HP .. those adapters are NOT the plan.
[Re: dOc !]
#832205
10/17/10 10:13 PM
10/17/10 10:13 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Yet another case of blaming the part rather than the mechanic
[Re: ScottSmith_Harms]
#832207
10/17/10 11:06 PM
10/17/10 11:06 PM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
Say what you want, there's a reason OTHER carter designs like the AFB is still being produced and thermobogs aren't.
[Re: CokeBottleKid]
#832208
10/17/10 11:09 PM
10/17/10 11:09 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
reason is a dummy can work on them.
[Re: ademon]
#832209
10/17/10 11:35 PM
10/17/10 11:35 PM
dOc !
Florida STAYcation
The REASON is ... is those AFB designs are simple UNefficent carbs that are EZ to produce ...... compared to the TQ.
And this stupid thermobog title ? ... if you TWEAK the carb right(with the proper tool ) ....
The CORRECT title would be thermoKICK .... as the secondaries come-in and SPIN the tires !
[Re: ademon]
#832210
10/17/10 11:41 PM
10/17/10 11:41 PM
CokeBottleKid
Detroit, MI
Let me be clear I'm not touting any of the carter designs, just pointing out which of their crappy ones are still in production.
[Re: dOc !]
#832213
10/18/10 12:31 AM
10/18/10 12:31 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: CokeBottleKid]
#832214
10/18/10 12:33 AM
10/18/10 12:33 AM
moparpollack
Lil Herman
Lil Herman
85086
A mopar m1 will work with no mods it's set up for a spread bore carb.
[Re: DEMONSIZZLER]
#832218
10/18/10 12:23 PM
10/18/10 12:23 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Why do you guys assume an adapter is robbing HP? Many Many guys find they go faster with a spacre and an adapter is almost the very same thing. Mabey I am the only one who does this but I like to take the adapter, bolt it on the intake and port it to smooth the transition till it is like one single piece of aluminum, thats how I roll with them on intakes not desighned for them and they seem to work VERY good. If you do that there is just no where for the HP to disapear Not all M1s BTW can have a t-quad bolted right on and since he is talking about air-gaps and LD340 intakes it sounds like he wants a dual plane and the t-quad will not bolt to a M1 dual plane, onlyt the M1 single plane.
[Re: HYPER8oSoNic]
#832223
10/19/10 09:41 PM
10/19/10 09:41 PM
Posts: 757 Toronto, Ont, Canada
boydsdodge
Why I ask is because the Thermoquad/LD340 combo works fantastic for me and what I use it for. But since I am having a hard time finding an LD340 and that the RPM Air Gap is a great intake along the lines of the LD, I thought it would be great to combine a Thermoquad and RPM Air Gap. Thats what/why I am asking.
[Re: boydsdodge]
#832224
10/19/10 09:58 PM
10/19/10 09:58 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Short answer, absalutely yes, great combo! Long answer....It depends on your engine combo, but still likely a good combo for most any a street car.
[Re: boydsdodge]
#832225
10/19/10 10:09 PM
10/19/10 10:09 PM
DaytonaTurbo
Manitoba, Canada
I would be tempted to try out one of the spreadbore holley double pumpers on it. I think that could also make for a nice combo on a street car.
[Re: HotRodDave]
#832226
10/20/10 10:23 AM
10/20/10 10:23 AM
Posts: 1,061 New Mexico
dmerc
New Mexico
That's funny, I have a thermoquad on my Dual Plane M1 intake. I used an adapter. Why won't it work?
[Re: dOc !]
#832228
10/20/10 10:20 PM
10/20/10 10:20 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
i love tqs
[Re: HYPER8oSoNic]
#832232
10/22/10 08:31 PM
10/22/10 08:31 PM
JonC
Millinocket, Maine
IIRC a few years back one of the mopar mags did a dyno test on those adapters and showed them to lose HP. However if they would have done like you describe, bolting them on then smoothing out the transition I suspect the loss would have vanished.
100% with you!! Good point Daytona!!
It still would be a tight if not impossible fit an a Cuda Ebody with twin scoop hood.
[Re: HotRodDave]
#832234
10/23/10 01:00 PM
10/23/10 01:00 PM
Posts: 3,075 Eastern Ohio
mopowergtx
Eastern Ohio
Original poster. Street car right? Why not just run a stock 71-78 cast iron intake? Heck probably get one for free if you bug enough buddies for what they got laying around. Worst case scenario maybe twenty bucks. Thats a 79 but I wish it was a 78 because of that stupid tin thermostat housing they started using and turned 45 degrees starting in 79. I missed that completely until after I sand blasted and painted it.
[Re: mopowergtx]
#832235
10/23/10 01:16 PM
10/23/10 01:16 PM
ademon
IL, Aurora
Not a bad idea, i dont think you would be giving up to much HP with a 71/72 intake, especially if modified and port matched but they are heavy !!!!
[Re: boydsdodge]
#832239
10/28/10 05:15 AM
10/28/10 05:15 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Yep, my TQ on a 318 stroker bogs all the way to 12.6 - and thats a NON reco carb, with 40 year old floats and bowl - and there's more in it. On topic - I have hogged out both an LD4B and an LD340 successfully - an air gap should prove no issue either. (PS - Don't listen to what some "others" on other sites have to say on this issue - they're yet to prove to be able to run a qtr time, let alone know what can and can't be done with a TQ and a 4B or LD........listrn to the Demon .)
[Re: Moparmal]
#832240
10/28/10 07:17 AM
10/28/10 07:17 AM
Posts: 607 NY
old340dog
NY
Is there a provision on the LD340 and the Air Gap for the automatic choke? Or do you use a manual choke. I've noticed this on my LD340 intake and have thought about using a TQ that I have.
old340dog
[Re: HYPER8oSoNic]
#832242
10/29/10 12:16 PM
10/29/10 12:16 PM
HotRodDave
Kalispell Mt.
I think some of you guys have never had a t-quad base plate sitting on an RPM or RPM air-gap, there just is not enough meat there to grind away, you have to weld up the flange area then mill it back flat then you can grind clearance for the blades and have a smooth transition. That is the only way it is gonna happen unless you run a thick gasket and only grind minimal clearance for the opening blade and in that case you have a big step that will hurt performance, possibly cause tuning issues and fuel seperation. You wil still be asking for vaccume leaks because there is only about 1/32 gasket clamping area if that(may vary a few thou either way depending on particular castings). I tried everything I could imagine to do it and ended up with a mr gasket adapter siliconed to the manifold and a thin gasket, an air cleaner fit just fine with a drop base in my 68 cuda, I would have guessed an e-body would have had a little more room but I really don't know about e-bodys.
[Re: HotRodDave]
#832243
10/29/10 01:15 PM
10/29/10 01:15 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
I have modified LD340 intakes for thermoquad use. They can be done nicely. It really helps to be skilled with a die grinder and it takes more time than most think. I've looked at perf RPM intakes with the intent of modifying for a thermoquad and concluded it could not be done without adding an adapter (to an already tall intake) or extensive welding.
Note: No aftermarket intakes that I have measured have as low a profile as an LD340. Going from memory, they are about 5/8-3/4 inch shorter than a perf rpm or weiand action.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: HYPER8oSoNic]
#832248
10/30/10 12:03 AM
10/30/10 12:03 AM
HotRodDave
Kalispell Mt.
Silicone is bad for intake to carb surfaces. Could you have tried J-B Weld on it and work an adapter? Silicone is TOO messy and disrupts the flow from the carb through the intake and to the heads! Food for thought!!
I just siliconed the spacer to the intake, then blended it in with the die grinder so no left overs hangin in the plenum.
I have done an LD4b and it has a different carb pad than an RPM, the LD4b and LD340 have basically tha same carb pad. It only took a couple minutes to rough it in. I used an 850 t-quad baseplate and a black marker to mark color everything in ther to remove, then I mounted a christmas tree carbide in a router and ran it around to remove all the black marker then hand blended the transition with a die grinder, almost looked like a cnc had done it when I was done.
