Wiper blades for a 74 Roadrunner? #831278
10/16/10 06:22 PM
10/16/10 06:22 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
Where can I find wiper blades that will work on a 74 Roadrunner.The wipers tuck down behind the hood & I can't find a set that will allow that to happen,they're all too tall.
Re: Wiper blades for a 74 Roadrunner? [Re: Rosco] #831279
10/16/10 07:09 PM
10/16/10 07:09 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Can you find blades with the same insert as what you have?
You could swap inserts and keep the same metal blade.
- Stu Harmon
Re: Wiper blades for a 74 Roadrunner? [Re: feets] #831280
10/16/10 07:45 PM
10/16/10 07:45 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
Unfortunatly, I don't have the metal blades.
Re: Wiper blades for a 74 Roadrunner? [Re: Rosco] #831281
10/16/10 08:57 PM
10/16/10 08:57 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Hmmm, anybody have a pic of what the blades should look like? I'm guessing they don't have the arched springs like exposed wiper blades do?
Re: Wiper blades for a 74 Roadrunner? [Re: Rosco] #831282
10/16/10 10:35 PM
10/16/10 10:35 PM
IMGTX Offline
IMGTX  Offline
I have the same problem. I haven't tried these yet but I found info in a previous thread.
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6206805
Shorcut to Trico Classic Blades
Re: Wiper blades for a 74 Roadrunner? [Re: IMGTX] #831283
10/16/10 11:01 PM
10/16/10 11:01 PM
BDW Offline
BDW  Offline
I had same problem with my Challenger, the Trico Classics did the trick. Look nice and are low profile too.
Re: Wiper blades for a 74 Roadrunner? [Re: IMGTX] #831284
10/16/10 11:07 PM
10/16/10 11:07 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
Mine also aren't the bayonet style,they're the pin style.
Re: Wiper blades for a 74 Roadrunner? [Re: Rosco] #831285
10/16/10 11:26 PM
10/16/10 11:26 PM
BDW Offline
BDW  Offline
Is the pin style the type where there is a pin on the wiper arm that slides into the hole on the wiper blade?
That's what I have, it's PN 33-162
Year One has them for $17, get them at Advanced Auto for $8
http://www.yearone.com/serverfiles/fbshopmain2.asp?input=wiper+blade&SM=1&SC=1
Re: Wiper blades for a 74 Roadrunner? [Re: feets] #831286
10/16/10 11:31 PM
10/16/10 11:31 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I have some if your in need. They will need refill blades...
Re: Wiper blades for a 74 Roadrunner? [Re: QuickBpBp] #831287
10/17/10 12:35 AM
10/17/10 12:35 AM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
nevermind...
Re: Wiper blades for a 74 Roadrunner? [Re: Rosco] #831288
10/17/10 03:56 AM
10/17/10 03:56 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Is this what you're looking for? I have a spare set somewhere... Like these, but without the integral washer nozzle in the arm.
Re: Wiper blades for a 74 Roadrunner? [Re: MoparMarq] #831289
10/17/10 10:24 AM
10/17/10 10:24 AM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
Mine would be similar.I'll try the Trico part# at the local parts store,Thanks guys.
Re: Wiper blades for a 74 Roadrunner? [Re: Rosco] #831290
10/17/10 11:35 AM
10/17/10 11:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
That or Ebay.I bought a new set of stainless ones for my 57 there.Still have them in the garage.I was going to install them but sold the car.Been thinking about using them on my 65.That or Ill just get refills for the old steel ones.Just hate to use new blades then have them sit all winter.Rocky
Chrysler Firepower
Re: Wiper blades for a 74 Roadrunner? [Re: therocks] #831291
10/17/10 09:42 PM
10/17/10 09:42 PM
BDW Offline
BDW  Offline
Re: Wiper blades for a 74 Roadrunner? [Re: BDW] #831292
10/17/10 11:09 PM
10/17/10 11:09 PM
the house on the left.
cogen80 Offline
cogen80  Offline
napa sells those classic blades also.
Re: Wiper blades for a 74 Roadrunner? [Re: cogen80] #831293
10/17/10 11:13 PM
10/17/10 11:13 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Out of cusriosity, do the original blades have some type or stamp or marking on them that would easily distinguish them from newer OTC replacement parts?
